Need Help, Pulling Electric Pto
1 reply to this topic
#1 farmer john OFFLINE
farmer john
  • 1,788 Thanks
  • 909 posts
Posted July 24, 2014 - 07:11 PM
hi guys, started doing a little clean up around the place on some parts tractors that were given to me, both wheel horses 244 and 212, both have electric clutches on good onan motors, in my experence you just remove the bolt and they fall off, these 2, no way and i have a puller on a 2 ton jack and they are not budging, am i missing a pin or clip somewhere, thanks
  • 5,418 Thanks
  • 4,703 posts
Posted July 24, 2014 - 07:16 PM
I removed an electric PTO clutch on a Raider 12.....
After removing the center bolt that threads into the crank output shaft, you should see threads in the electric clutch that are larger than the bolt you 1st removed.
After using lots of penetrating oil, thread a long bolt (or threaded rod) into the clutch. The bolt will bottom out on the crankshaft and push the clutch off. The push bolt should be large enough that it won't damage the internal threads on the crank.
Edited by KC9KAS, July 24, 2014 - 07:17 PM.
  • JDBrian said thank you
