Bolens Clutch Disk
3 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted July 23, 2014 - 08:20 PM
I have to replace a clutch disk on the bosses 900 bolens. I am getting one from a member on here. So my question is how are these installed. I understand the clutch comes all apart but how does it attach to the clutch plate?
#2 Bolens 1000 ONLINE
  • 14,898 Thanks
  • 18,099 posts
Posted July 23, 2014 - 08:56 PM
They should always come with instructions when you buy them......
Depending on what year the discs were manufactured determined the temperature and amount of time required in the oven.
With the bearings out and clutch completely disassembled you need to clamp the clutch tight together then bake in the oven.
Often a long threaded rod can be used to tighten down the clutch.
  • trowel and boyscout862 have said thanks
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 23, 2014 - 09:04 PM
wow bake in the oven?? Seems like we just had the talk about using the wife's toys for GT work.
#4 boyscout862 ONLINE
  • 12,521 Thanks
  • 9,031 posts
Posted July 24, 2014 - 05:19 AM
Pick up a cheap 110v oven at a tag sale. I've used mine for 25 years now. Bakes soil samples, shaft collars, press-on bearings, and connecting rods. Good Luck, Rick
  • trowel said thank you
