Anyone Use The New Plastic/metal Air Pipe?
23 replies to this topic
#1 glgrumpy ONLINE
  • 7,199 Thanks
  • 6,909 posts
Posted July 22, 2014 - 07:24 PM
My garage is set up with one big main pipe and drop can come off in a few places I put in for other sides and such. I never did use only one by big door. I want to run one to bench and another to other side to hook up Blasters and outlet there. Eastwood and others offer this kit that looks just like Pex pipe and special outlets and elbows, etc. Kinda costly, but quick to put up I think. The newest version is a two  layer plastic with flexible layer of aluminum in it. I think that might be improvement. Think Northern Tools has that one in catalog. Thinking of getting the kit and see how it works. Anyone else ever do this and how is it? I'm wondering about holding up in winter cold and not cracking or shattering then?  Would think it would be safe, or they couldn't sell it. I have not found any of this in any local hardware or farm stores. Someone said Menard's lumber had it, but forget to look when in there. Might be next garage improvement this fall.
  • MH81, hamman, HDWildBill and 2 others have said thanks
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,409 Thanks
  • 1,329 posts
Posted July 22, 2014 - 07:38 PM
I look forward to seeing any comments on this. I have looked at the kits and it appears to be easy to set up.
Geno
#3 shorty ONLINE
shorty
  • 4,194 Thanks
  • 4,421 posts
Posted July 22, 2014 - 07:59 PM
I hadn't heard of it before. Sure sounds interesting. Let us know if you use it.
#4 JDBrian OFFLINE
  • 9,593 Thanks
Posted July 23, 2014 - 04:10 AM
I second that!  Putting up a rigid pipe and fittings system would be piles of work. This would be a big time saver.
#5 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,156 Thanks
  • 1,330 posts
Posted July 23, 2014 - 05:17 AM
I have been running 1' main and 3'4" drop schedule 80 PVC since 2005 and the only problem I have have had is last winter I put in a new wall mounted heater and the pipe about three feet above it must have gotten too much heat and the air pressure caused it to swell and develop a slow leak.  I changed the eight feet above it to 1" black pipe.
  • Alc and HDWildBill have said thanks
#6 skyrydr2 ONLINE
  • 3,672 Thanks
  • 3,304 posts
Posted July 23, 2014 - 05:41 AM
Are you kidding?? That stuff is WAY safe!! All the trucks on the road today are using this stuff for there air lines for their brakes! That stuff is incredibly durable and all the new fittings with push lock features are so nice to use. We use miles of the stuff where I work for airlines and such.
  • DougT, GTTinkerer, HDWildBill and 2 others have said thanks
#7 js5020 OFFLINE
js5020
  • 570 Thanks
  • 704 posts
Posted July 23, 2014 - 08:51 AM
I was under the impression that PVC was not to be used for pressure applications because when it fails it shatters with grenade like tendancies,,, the pex will not shatter, we use it at the job with little problems.
#8 Cvans OFFLINE
  • 5,026 Thanks
  • 5,362 posts
Posted July 23, 2014 - 09:06 AM
This is very true. At least he is using schedule 80. If the pressure switch would fail the relief valve should keep things safe. This is an excellent reason to manually operate the relief valve occasionally to keep it clear of foreign materials.
#9 Alc ONLINE
  • 5,921 Thanks
  • 6,889 posts
Posted July 23, 2014 - 10:36 AM
Is this the stuff you guys are talking about ?
http://www.rapidairp...om/rapidair.asp
  • glgrumpy said thank you
#10 HDWildBill OFFLINE
  • 8,917 Thanks
  • 8,645 posts
Posted July 23, 2014 - 10:48 AM
Al, you beat me to it.  I was going to ask the same question.  This one at Northern Tool seems to have everything you need to install except the water filter.
  • Alc and glgrumpy have said thanks
#11 glgrumpy ONLINE
  • 7,199 Thanks
  • 6,909 posts
Posted July 23, 2014 - 02:28 PM
Al, that is the stuff, cept the one I saw last had aluminum layer in tube to help keep it more stiff? or whatever. Eastwood I think is where I saw that. This site says watch out for imposter brands, hmmm! This kit shown on that page is actually quite a bit cheaper than most catalogs are offering and has better looking outlets. Think I'll try this brand when I do it, thanks for the lead!
#12 HDWildBill OFFLINE
  • 8,917 Thanks
  • 8,645 posts
Posted July 23, 2014 - 02:33 PM
Do you have a link to the brand you were looking at?  The description on the kit I linked to off Northern said it had an aluminium lay in it.
#13 Bill 76 ONLINE
Bill 76
  • 1,755 Thanks
  • 1,114 posts
Posted July 23, 2014 - 03:38 PM
I used copper pipe when I did my garage wasn't hard to cut and sweat the fitting togrther-----But this concept sounds like a good idea and I like the plug and play part,sounds easy.Kinda wish it was around when I plumbed my air.
#14 glgrumpy ONLINE
  • 7,199 Thanks
  • 6,909 posts
Posted July 23, 2014 - 04:07 PM
Wild Bill, think that was in Northern in new catalog this spring.  I've been looking at this stuff for couple years, so not sure where I saw all the items. Eastwood was first overpriced place, then later Northern had that improved stuff. I'm gonna go back and look at the link above now.
  • HDWildBill said thank you
#15 Sawdust ONLINE
Sawdust
  • 4,846 Thanks
  • 2,973 posts
Posted July 23, 2014 - 05:45 PM
I haven't tried it yet but have read about it. After using Shark Bites & all the quick connectors on my jobs I can see this being the way to go. I would do some research on the so called imitations. Since it has been out for few years I would think the competitors are just as good depending on the price difference. Let us know what you do GL great topic glad you brought it up.
