* * * * * 3 votes
Forklift
54 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,265 Thanks
  • 1,741 posts
Posted July 21, 2014 - 03:30 PM
I bought a small forklift from Josh ( AKA: talntedmrgreen ), to use in my new garage.
According to the engine serial number, this is a 1956 Kalamazoo Xpediter  Model-301.  This was built by the Kalamazoo Manufacturing Co. in Kalamazoo, Michigan.
This forklift is about 81 inch long, 33 inch wide and 55 inch tall and weighs 1,022 pounds.
Here is an old advertisement for the forklift.
The right front tire was flat and the hub and wheel was removed so a regular spindle mount tire could be put on it so it could be moved around.
Somewhere along the line, the outer bearing got misplaced so after we got it loaded, we removed the temporary wheel and set it down on some blocks of wood.
Here are a couple of shots of it up on the truck.
Before I can get it off the truck, I need to fix the flat tire and get it back on the front.
The belts for the hydro drive and the hydraulic pump were slipping really bad when we loaded it so they need replacing also.
Saturday I took the wheel apart and found out that the tube just needed a patch.
The bearing and belts are available at my local auto parts store but they won't be in until Monday.
While I'm waiting for those parts, I stuck a battery in.
I don't think these little garden tractor batteries were even being made back in the mid 50's so the battery box is made for a full size car battery.
I put a piece of 2x6 in the bottom of the battery box so this battery didn't set down in so far.
Even with it setting up higher, it still looks sort of lost in the box so I made up a wood cover for it to make it look a little better.
It's Monday morning and the parts are in and the wheel hub is back on the front.
Then the wheel is bolted back on.
Last thing to do was get the belts back on.
You may have noticed the open exhaust pipe sticking out above the belts.
The old muffler was located back along side the operator and was covered with this ugly shield.
The muffler was all rusted out along the bottom so I cut it off.
I'm going to put a new muffler on and point it away from the operator.
KalamazooXpediterModel301-3_zps1946dd72.
That brings us to unloading time. .....
There is an area down the side road where I can back the truck into to make it easier to unload.
Careful now, I don't want to run this off the ramps and tip it over because I don't have anything here that can pick it back up.
Okay, that was easy.   And off we go across the yard.
Oh Oh, something is wrong !   She starting to sputter and loosing power.
I see what's wrong.  The high speed screw is turning in and out from the engine vibration.
Turns out the little "O-ring" that seals around the screw is completely gone.
Run to the hardware for a new O-ring and now it runs fine.
Here she is finally up by the garage.
The lift boom tilts back and forward with no problem but the forks are stuck in the up position.
The lift cylinder is suppose to have power up and power down so I'm going to have to figure out why they won't come down.
These were built for a specific purpose so the forks are rather short and they don't lift very high.
Somewhere in my stuff packed away at my son's place, I have a fork lift boom that was mounted on a three point hitch on the back of a 8N Ford tractor
I'm going to put that boom and forks on this forklift so it will have longer forks and lift higher.
Edited by jdcrawler, July 21, 2014 - 03:39 PM.
  • olcowhand, wilberj, Gtractor and 21 others have said thanks
#2 Talntedmrgreen OFFLINE
  • 3,176 Thanks
  • 2,253 posts
Posted July 21, 2014 - 03:51 PM
Wow Ray!  Sure looks easier coming off than going on!  :thumbs:
Your truck seems to also work well as an elevated work station...another reason I need one of those :worshippy1:
I beleive that book weight for the rig is for the unit alone....the facotry counterweights were optional and add to the total weight.  What do you figure each of those babies weigh?  Can I ask how you went about the flat tire problem?  I know it probably wouldn't handle much, if any weight, on air alone :(   I sure am looking forward to your project and feel it is in PERFECT hands!  I'm quite excited to see how this goes, and really do plan on visiting to try it out when it's done :smilewink:
  • jdcrawler, hamman and tinbender7 have said thanks
#3 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted July 21, 2014 - 04:05 PM
Sweet! Cool little unit!
Sent from my potato using Tapatalk
  • jdcrawler said thank you
#4 Arti ONLINE
Arti
  • 1,359 Thanks
  • 985 posts
Posted July 21, 2014 - 04:54 PM
That's an amazing forklift. Bet you have a lot of fun with it.
#5 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,265 Thanks
  • 1,741 posts
Posted July 21, 2014 - 05:08 PM
It was definitely easier coming off than going on.
The two counterweights are a good size piece of cast iron each.  I would think they  weigh about 250 to 300 pounds each.
The tires on it are the original tires so eventually I'm going to change all the tires  over to 6 ply trailer tires.   The 6ply tires are rated at about 745 pounds each at 90 pounds pressure and look like this.
Edited by jdcrawler, July 21, 2014 - 05:34 PM.
  • hamman and TomLGT195 have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted July 21, 2014 - 06:00 PM
That is one nice piece of machinery.  I need one.
Ben W.
  • jdcrawler and hamman have said thanks
#7 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,265 Thanks
  • 1,741 posts
Posted July 21, 2014 - 07:04 PM
For those that would like to see this,  it turns out that this and my truck will be at the Buckley Show after all.
The show runs August 14 thru 17.
Edited by jdcrawler, July 21, 2014 - 07:04 PM.
  • Texas Deere and Horse and KennyP have said thanks
#8 KennyP ONLINE
  • 33,202 Thanks
  • 42,670 posts
Posted July 21, 2014 - 07:52 PM
That is a cool machine! Glad you have it in your care! Waiting for updates!
#9 Canawler OFFLINE
Canawler
  • 1,933 Thanks
  • 1,786 posts
Posted July 21, 2014 - 08:03 PM
Wow. I didn't think Josh would let that one go being a Michigan built product.
Wait, this must mean he has a line on a nicer one....
  • jdcrawler, IamSherwood and Talntedmrgreen have said thanks
#10 OldBuzzard ONLINE
OldBuzzard
  • 6,747 Thanks
  • 4,712 posts
Posted July 21, 2014 - 09:19 PM
VERY cool lift truck :thumbs:
You might find these links of interest:
http://www.kalamazoo.../expediter1.jpg
http://www.kalamazoo.../expediter2.jpg
http://www.kalamazoo.../expediter3.jpg (same as the one you posted)
http://www.kalamazoo.../expediter4.jpg
#11 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted July 21, 2014 - 09:46 PM
That lift was probably a pretty expensive unit in it's day.
#12 hvychevy2o OFFLINE
hvychevy2o
  • 24 Thanks
  • 25 posts
Posted July 22, 2014 - 07:14 AM
wow this is so great i cant wait to see your progress
  • jdcrawler and Talntedmrgreen have said thanks
#13 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted July 22, 2014 - 05:53 PM
I need that !!! Thats a cool machine never seen one those before,Nice truck too!
#14 Cat385B ONLINE
    Therapy CAT
  • 12,826 Thanks
  • 9,452 posts
Posted July 22, 2014 - 08:05 PM
Oh sure, I show up late to this thread and all that's left is the folding chair next to the porta-pot. Thanks for saving me a seat in the front row guys. Ben, I'm looking in your general direction. I'll get your seat, at your advanced age that bladder can't hold much longer.
#15 UncleWillie ONLINE
  • 14,213 Thanks
  • 8,181 posts
Posted July 22, 2014 - 08:21 PM
Does the boom tilt on those?
