Pto Clutch Removal
1 reply to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 21, 2014 - 11:59 AM
If someone wants to pin this, it may be helpful to many.
Since my brother showed me how he removes a PK clutch flywheel, I won't do it any other way.  This method will inflict no damage tot he block or the flywheel and it's pretty quick.  I use 4 wood splitting wedges, two on each side of the shaft, positioned as you see in the pictures.  Once they are set up, you simply hit each of the top two wedges alternately.  As you do, the flywheel begins to move.  If the wedge hits bottom before the flywheel is loose enough to take off by hand, simply put a shim or block of some sort between the engine block and the upward pointing wedge and do it all over again.  I just took these pics yesterday.  I had the flywheel off in about 5 minutes.  Of course you want to make sure you have all set screws out (there may be two in each hole) and you may want to soak in PB Blaster for a while if the pulley is really stuck.  I did not soak this one but it wasn't on there very long (couple years).
Putting the top wedge on
All 4 wedges in place and ready to go.
Edited by David Brown, July 21, 2014 - 12:01 PM.
  • Gtractor, Username, countryboy88 and 2 others have said thanks
#2 Arti OFFLINE
Arti
  • 1,388 Thanks
  • 1,002 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted July 21, 2014 - 04:59 PM
That's a great idea. I've been doing about the same thing with a pickle fork/ball joint remover. This looks like it would work even better.
