Help - Identification Of Walk Behind Tractor
walk behind identification ward
19 replies to this topic
#16 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted July 21, 2014 - 07:40 PM
Yours has those holes, two are open like you see in the picture, the other two are drilled and tapped into the sump so this base can fit either sizes.
Well, cr**.  You are right!  Not sure how I missed them.
  • trowel and hlone have said thanks
#17 hlone OFFLINE
hlone
  • 6 Thanks
  • 5 posts
Posted July 21, 2014 - 09:04 PM
We took the engine off tonight and the base looked exactly like the one in your picture.
#18 hlone OFFLINE
hlone
  • 6 Thanks
  • 5 posts
Posted July 21, 2014 - 09:42 PM
Tonight we pulled the Engine off the frame and based on the comments and looking at the information on this site it is a Model B since it doesn't have a 4 speed transmission like the Model D.  The Clinton engine is a 3 hp based on looking at the engine tag more closely.
Based on the simple construction we will clean up the tractor and restore it.
Next Question for the engine - We pulled everything apart except for the case and here my next question to the group is where is the best place to get gaskets for the engine.  It may also need a set of rings.
The Carb is a Carter Model N
Pics of the Carb:
Pics of Points:
Pics of Cylinder:
Pics of the Frame:
#19 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted July 22, 2014 - 05:30 AM
http://gardentractor...aths-equipment/
How was you able to ascertain the hp figure from the tag, is this one rated at the 3600 or 3200 rpm ?
#20 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted July 22, 2014 - 07:09 AM
Ditto on the Superaben (Old Paths) referral.
  • trowel said thank you
Also tagged with one or more of these keywords: walk behind, identification, ward
