Help - Identification Of Walk Behind Tractor
walk behind identification ward
19 replies to this topic
#1 hlone OFFLINE
hlone
  • 6 Thanks
  • 5 posts
Posted July 20, 2014 - 08:04 PM
Help - Identification of a Walk Behind Tractor!
I picked up this walk behind for $15 this weekend that has been sitting for 40+ years in an old shed. It has a Clinton engine on it that is free / turns over and actually has clean oil in it. The tires junk, but have a Wards name on them.
The few identification tags I have found are as follows:
Clinton Engine Model #: C1101A0C Serial # 2098703 A
On the Transmission there is a tag Serial # SS12580R
On the Axle it has a cast # of SSB19
To add weight to the tractor they made a form and put concrete on the back side of each rim!
Any help would be appreciated.
Edited by hlone, July 20, 2014 - 09:31 PM.
#2 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted July 20, 2014 - 08:11 PM
Most likely a Montgumery wards made by Simplicity.
Forties to early fifties.
Joe
  • trowel, boyscout862 and hlone have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 20, 2014 - 08:22 PM
Welcome to the fourm, that's a cool tractor, the tractor looks like Montgomery Wards, late 40's to early 50's, the Clinton engine will tell us that, regarding that, the model number you gave should start with a letter not a number, clean the tag a bit more and see if it does not read B1101AOC, upload a few more pictures of the engine if you could, i would like to see the throttle arrangment.
Ben of Old Path Equipment on this fourm may have the needed parts to make that Clinton run should it need any.
I see the second hand lever for powering attachments, that is neat it has that.
  • boyscout862, New.Canadian.DB.Owner, Rock farmer and 2 others have said thanks
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 20, 2014 - 08:38 PM
That looks like a hefty little tractor.
Those handles say model Simplicity B to me, as well as the wheel pattern, but since Simplicity/Monty Wards painted on the model information its really anyone's guess.
Ben W.
  • Bolens 1000, trowel, boyscout862 and 1 other said thanks
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 20, 2014 - 08:53 PM
Going out on a limb, here it look exactly like the one I just got. Mine  had no engine, but  I think it Wards model of a Model B simplicity. Wards called their Clinton power one a chore trac. Mine has a barely readable tag on the top of the gear box. looks like this one does also. maybe if you carefully clean it off, you can learn a little more about it.
#6 hlone OFFLINE
hlone
  • 6 Thanks
  • 5 posts
Posted July 20, 2014 - 09:22 PM
Thanks for the Information.
Here are a couple more pictures of the Tractor
Engine Serial Starts with letter "C" now looking at the picture again:
Levers:
Bracket Below Engine:
  • trowel and boyscout862 have said thanks
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 20, 2014 - 09:40 PM
Thanks, you have another double letter Clinton and this is the 4th one i have seen, 3 on tractors, one i own, model C1101AOC, the first letter A is something of a paradox for the walk behinds, i have reasons to assume that it is only for walk behinds seeing as no other Clinton engine that i know of has the double letter.
The engine is mid 54 to 56, not as early as i originally thought, C1101 type A,  2 hp, 4 variants of this engine was MFG'ed, you have the variable speed one with the later # 26 Carter N carb, i can see a hint of it in the photo with the special air horn for the throttle cable, only for power equipments and walk behind tractors, it should have the plastic Saf-T-Vue air cleaner atop the air horn.
Photos of the throttle arangment and carb would help me further.
  • boyscout862, superaben and hlone have said thanks
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 20, 2014 - 10:42 PM
im thinking if that engine date is correct, then its newer than the tractor, as tractor model is from the late 40's to early 50's.
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 21, 2014 - 05:04 AM
Thanks Jeff, the date was bothering me so i double checked this morning before sighing on, the Simplicity B was mfg until late 52 to 53, the B series was already 4 years in productions so it did not feel right to have such a large gap between engines.
I double checked the model # and it came back as coming out 2 years after the B series around late 51early 52 with the round bowl Carter N, his model # is one of the first, C1101 type A so i stand corrected on the date.
It would seem it is all original right down to the tires.
  • boyscout862 and hlone have said thanks
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 21, 2014 - 05:07 AM
Levers:
What are your intentions with this tractor, are you going to restore it ?
  • hlone said thank you
#11 boyscout862 ONLINE
  • 12,520 Thanks
  • 9,028 posts
Posted July 21, 2014 - 05:54 AM
Welcome to GTT. Check out our Manuals Section for 3 free downloads per day. Good Luck, Rick
  • trowel and hlone have said thanks
#12 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted July 21, 2014 - 07:18 AM
I agree with the assumption that it is a re-power.  Check out the engine mounting bolt locations.  It looks like someone drilled new holes in the mounting flanges for the smaller bolt pattern.
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 21, 2014 - 05:19 PM
I don't think I've seen this shape of base before either, but then again I don't have many Clinton powered unit. I had wondered about the holes being redrilled, but I think I would have had to see the part in person to decide. Looks like this tractor was rode hard a few times.
#14 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 21, 2014 - 05:58 PM
Yours has those holes, two are open like you see in the picture, the other two are drilled and tapped into the sump so this base can fit either sizes.
Edited by trowel, July 21, 2014 - 05:59 PM.
#15 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 21, 2014 - 06:02 PM
One of the most commonly used base was that one, universal, i see on a lot of Clintons throughout the series.
Yeah, she was used hard and put up wet.
Also tagged with one or more of these keywords: walk behind, identification, ward
