Differences Between Bolens 1256 And 1886 ?
3 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 20, 2014 - 04:12 AM
Is the frame on the 1886 longer ? Can most parts/engine interchange between the 1256 and 1886 ?
#2 OldBuzzard ONLINE
OldBuzzard
  • 7,019 Thanks
  • 4,791 posts
Posted July 20, 2014 - 04:21 AM
The 1256 is a Tube Frame, and the 1886 is a Large Frame.
There would be almost nothing that would interchange between the two.
It would be like asking if parts would interchange between a Ford Escort and a Crown Victoria :D :D :D
#3 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted July 20, 2014 - 05:31 AM
I have 6 tube frames and 3 large frames. Once you have a large frame you will prefer it over all others. I use my 1250 the most. It is an example of bigger is better. Good Luck. Rick
  • trowel said thank you
#4 OldBuzzard ONLINE
OldBuzzard
  • 7,019 Thanks
  • 4,791 posts
Posted July 20, 2014 - 11:14 AM
Well now, I wouldn't go so far as that.
Tube frames to have their advantages.  Maneuverability being one of them.  Large frames have the turning radius of the USS Ronald Reagan :D :D :D
Tube frames also have a much wider assortment of attachments available. so there are jobs that you can do with a tube frame that you can't do with a large frame.
That said, if it's a job that either can do, I will almost always use one of my large frames :D :D :D
  • EricFromPa said thank you
