So It Begins. Taking It Apart And Tinkering With It. Ss12
17 replies to this topic
#1 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 17, 2014 - 03:04 PM
I have been tinkering with my SS12.  Taking it apart.  Squirting nuts and bolts with wonder penetrant.
New bearings on the front wheels.  Took the light switch apart and freed it up.  Same with the choke cable.
Think I might keep it ratty looking but get the mechanical bits back up to par.
Anyone know the proper routing of the throttle cable?
Going to tackle the wiring here pretty soon.
  • MH81, JDBrian, tinbender7 and 2 others have said thanks
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 17, 2014 - 05:02 PM
Looks like you are off to a good start. The wiring always seems to be a mess on these older GTs. I usually start over and renew everything when it's been "modified" by previous owners.
  • tinbender7 and Sawdust have said thanks
#3 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 17, 2014 - 05:11 PM
Aye. Have a mess of wire at the shop. I hate crimp connections. Solder is the way to go.
#4 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted July 17, 2014 - 08:17 PM
I don't have an answer about the throttle cable routing, but I will check tomorrow.  Perhaps someone will reply before I check.
#5 MH81 OFFLINE
Posted July 18, 2014 - 07:07 AM
I believe it goes under the battery tray and around the "passenger side" of the head. I don't remember if it attaches to a head bolt or not.
Will be tomorrow before I'm near mine, Robert, grab a couple of pics?
#6 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted July 18, 2014 - 08:51 AM
Choke runs under battery tray to top of carb
Fuel runs down under flywheel tin and connects to governor linkage
Had to edit this one in paint and upload. Follow above the red line for cable.
  • MH81, sacsr, New.Canadian.DB.Owner and 2 others have said thanks
#7 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 18, 2014 - 07:51 PM
Thanks Tahoe.
#8 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted July 19, 2014 - 09:02 PM
Mine goes to the left side of the engine, and under the flywheel cover/shroud.  it fits real tight, almost like it is to short.  Sorry I didn't get back in here sooner.
  • MH81 and hrhoward have said thanks
#9 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 21, 2014 - 03:47 PM
Today got a pesky oil leak fixed.
Was leaking around this screw on the valve cover / breather. (arrow)
20140721 151502
Took an air hose and blew out this tube.  Old dirt-dobber nest was clogging it.
20140721 151426
No more leaking. :thumbs:
  • MH81 and sacsr have said thanks
#10 MH81 OFFLINE
Posted July 21, 2014 - 07:27 PM
Crankcase breather. Huh, you'd think with the oil and whatnot in there, they would've stayed out.
Glad it was an easy fix :thumbs:
#11 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 23, 2014 - 01:46 PM
Made a little video of me driving around the outside of the shop.
http://youtu.be/YIn0NRSdwR0
  • Brando and Sawdust have said thanks
#12 Sawdust OFFLINE
Sawdust
  • 5,656 Thanks
  • 3,368 posts
Posted July 23, 2014 - 05:56 PM
Looks like a little joy riding too. Great to see you getting some seat time.
  • hrhoward said thank you
#13 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 24, 2014 - 03:02 PM
Some more photos from underneath.
Transmission, steering, idler, brakes.....
Transmission Hi Lo (2)
Transmission Hi Lo (1)
Steering (3)
Steering (2)
Steering (1)
Idler Bracket Set Up (2)
Idler Bracket Set Up (1)
Brakes (2)
Brakes (1)
Finding all kinds of things to do!! :D
#14 hrhoward OFFLINE
hrhoward
  • 36 Thanks
  • 16 posts
Posted July 24, 2014 - 04:36 PM
Don't believe the brake linkage is original.
Also going to have to do something with the end on the drag- link.
#15 MH81 OFFLINE
Posted July 24, 2014 - 04:44 PM
Wow, that was really "re-engineered"
Neat, thanks for the pictures.
