Junker A/c Big Ten Cleaned Up, Running, And Put To Work!
26 replies to this topic
#16 boyscout862 OFFLINE
  • 13,688 Thanks
  • 9,474 posts
Posted July 18, 2014 - 07:12 AM
Add Marvel Mystery Oil to the gas. 1 tablespoon per gallon. It will clean and lubricate the combustion chamber and piston including the rings. Good Luck, Rick
  • trowel and classic have said thanks
#17 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted July 18, 2014 - 08:41 AM
Thanks for the tips guys. I'll keep an eye on the oil level since I don't have the parts to rebuild it yet. I should be able to get around to the engine overhaul within a couple of weeks. The baffle is burned out of that muffler and it's way too loud, so a repro Nelson has got to go on this thing.
Edited by classic, July 31, 2014 - 10:00 PM.
  • trowel and boyscout862 have said thanks
#18 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted July 31, 2014 - 09:49 PM
Well, I've mowed with the tractor twice and hauled a few things around the property and the tractor has been running great. I do smell a little burning oil from the exhaust, so I'll be throwing a new piston and rings in it soon. I found an NOS piston assembly with chrome rings on ebay for 25 bucks shipped! I found a couple of pairs of Guide headlights in need of some work, but at least I have a decent pair to use. The light bar came in today, so I tossed it on to see how it will look. I'm going to paint the rims, the wheel weights, and the dash to clean it up a bit. I put the Nelson muffler on it from a different Big Ten and it sounds like it should, but it needs a coat of exhaust paint. I still have some more cleaning up to do on the tractor, but it's coming along.
  • MH81, trowel, Cvans and 1 other said thanks
#19 MH81 OFFLINE
  • 29,979 Thanks
Posted August 01, 2014 - 07:07 AM
Very nice tractor. I'm sure the engine refresh will be an improvement.
  • classic said thank you
#20 boyscout862 OFFLINE
  • 13,688 Thanks
  • 9,474 posts
Posted August 02, 2014 - 09:35 AM
I've saved many engines over the last 47 years with just the Marvel. Try it and you may save yourself some time. Good Luck, Rick
#21 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted August 02, 2014 - 11:21 AM
When I had the head off to remove the carbon, I could see that the ring end gap looked to be well over .030. I had a new set of rings in the shed, so I slid one down in the bore and the ring end gap was .011-.013,so the old rings are a bit worn. It won't take long to toss the new piston and rings in and get some more life out of it.
Edited by classic, August 02, 2014 - 11:37 AM.
  • MH81, trowel and boyscout862 have said thanks
#22 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted November 11, 2014 - 10:57 AM
I have a big ten and it's a great little tractor
#23 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted November 11, 2014 - 11:38 AM
Nice tractor.  I would suggest John Deere Muffler black paint for the muffler.  It works great and stays in place with time and heat.
#24 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted November 22, 2014 - 08:35 PM
Nice tractor you got there. When you put in the new piston and rings, give her a light honing, it does wonders. And as the others said, Marvel is awesome.
#25 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted November 23, 2014 - 11:05 AM
Thanks for the tip on the muffler paint Trav, I'll give it a try. The engine from this Big 10 will be going in another Big 10 that I'm restoring Junk Doctor. I've since installed a 16hp Briggs in this tractor and I use it regularly now. I picked up a Garden Mark Squire the other day and it ran well, but also did burn oil. I installed another piston, new rings, and a new connecting rod in the Squire, and no more smoke. Lightly honing the cylinder is a given on a rering job or a rebuild. Most of these old Briggs engines I've pulled apart have heavily worn rings from years of use. In most cases, a new set of rings is all they need.
Here's a pic of this Big 10 now with the 16hp, and the Squire.
Edited by classic, November 23, 2014 - 11:06 AM.
  • trowel and The Junk Doctor have said thanks
#26 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted November 23, 2014 - 12:29 PM
16 HP? I like the way you think.
#27 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted November 23, 2014 - 04:21 PM
The 16hp Briggs came in an Allis Big Ten that I picked up for parts. It's a great running engine, so it's in the Big 10 that I'll use the snow thrower on this winter.
  • trowel said thank you
