Wisconsin Aeh Repower
11 replies to this topic
#1 nofuntime OFFLINE
nofuntime
  • 4 Thanks
  • 5 posts
Posted July 15, 2014 - 06:56 AM
New member here. own a '40s? PK with a Wisconsin AEH engine,
problem is...engine has been sitting in the weather ingesting rain and such.
thought i would try to take it down for repair but the flywheel has become fused to the crankshaft.
I plan on using this tractor around the house so I wonder if there is a engine that would bolt up and get me going without a lot of machine work? i know this sounds vague but if you need any specifics of the tractor i will provide what i can.
thanks! Dave
  • Matthencix, Maroldarer, Clintomsata and 1 other said thanks
#2 Alc ONLINE
  • 6,912 Thanks
  • 7,473 posts
Posted July 15, 2014 - 07:34 AM
Welcome to GTTalk !!!   , I can't help you with your question but there are others that I'm sure can
#3 boyscout862 ONLINE
  • 12,869 Thanks
  • 9,180 posts
Posted July 15, 2014 - 09:05 AM
Welcome to GTT. Be patient. Soak the flywheel connection with PB Blaster twice a week for a month and then try to take it apart. I had an impossible bolt on a truck that took 6 months of soaking that finally came off intact. You may be able to find a replacement engine on an old piece of farm equipment. Check our Manuals Section for what you need. Good Luck, Rick
  • Alc and New.Canadian.DB.Owner have said thanks
#4 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Hi,
You can put anything from a '50's/'60's/'70's Economy Power King tractor easily enough into an early Economy.
For a user tractor the best bet would be a Kohler 12 or 14 hp K series engine. You would gain a more modern engine, parts availability, and electric start(if the Kohler is equipped). I would recommend getting a Kohler with the Power King mounting "ring" for properly locating the bellhousing. I would stay away from a Briggs as they typically have a 1" dia crank vs the 1 1/8" dia of Wisc and Kohler. If you were closer, I have a few K's that would make good candidates for your project.
Where are you located in NC?
Good Luck.
Chuck
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 15, 2014 - 10:29 AM
Have you checked the transmission to see if it ingested water. That could be a real problem if it was sitting a long time.
#6 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,141 posts
Posted July 15, 2014 - 10:30 AM
Why not rebuild the Original engine?
#7 nofuntime OFFLINE
nofuntime
  • 4 Thanks
  • 5 posts
Posted July 18, 2014 - 09:23 AM
well...thank you all for your replies!
i tried soaking it for an entire winter..i would spray it while i had the puller attached with some tension on it. every few weeks i would apply a little heat to it and soak it some more...this went on until i had gone thru 3 pullers,either the jaws would snap,or the center bolt would bend from the torque it had on it.
at this point I would like to mate a running engine with it until i get the rest of the tractor sorted out.
the trans is a question mark i haven't dived into yet..was gonna get into it and the clutch when i have the engine off the frame to correct the sloppy steering arrangement that was bubble-gummed on many moons ago..
i was thinking of getting a rack and pinion unit out of the salvage yard and mate it to the shortened Ford axle and spindles that are on it.
the Kohler sounds doable if i will be able to bolt the clutch housing to it.
i am in Clayton,NC
Thanks again!
David
#8 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted July 18, 2014 - 01:22 PM
Hi,
Tell us a little more about your tractor. Is it a chain steer tractor or does it have a Ross steering box?
The sn from the tag on the bellhousing will help id the year made. Also post some pics.
Chuckor
  • nofuntime said thank you
#9 nofuntime OFFLINE
nofuntime
  • 4 Thanks
  • 5 posts
Posted July 19, 2014 - 05:56 PM
just posted some pics in the economy/pk section.
#10 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted July 20, 2014 - 06:34 PM
Hi,
It looks like you have a Chain Steer Economy that has been "modified".
What does the plate on the bellhousing have for a sn?
The front axle and steering parts are not original.
The AEH should have a magneto but this looks to have an automotive coil installed and would need a battery to run.
What size are the rear wheels and tires? 22" or 24"
Are the rear axles splines or have a keyway?.
Chuck
Edited by EconChuck, July 20, 2014 - 06:38 PM.
#11 nofuntime OFFLINE
nofuntime
  • 4 Thanks
  • 5 posts
Posted July 21, 2014 - 03:18 PM
serial #1089
mag is there...stuck flywheel blocking it
keyway axles,24" tires
new tires that came with tractor
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 21, 2014 - 03:40 PM
serial #1089
That's a 1948 and it most certainly began life as a chain steer.  Wow, you have a lot of work ahead of you.
