John Deere 318 And A 35A Tiller
10 replies to this topic
#1 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 15, 2014 - 05:00 AM
I have a opportunity to pick up a model 35a tiller.  Can my 318 handle it ok?  Or is it too big for it?
#2 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted July 15, 2014 - 06:42 AM
35 a Tiller is for the 400 tractors it uses an odd pto speed and drive shaft .As for the weight of the tiller the 318 will handle it with some weight up front
#3 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 15, 2014 - 10:04 PM
Isn't the pto for a 318 the same as used on a 400?
#4 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted July 15, 2014 - 10:09 PM
The 400 uses a odd rear output pto speed of 880 rpm if I remember correctly. I'm not sure if you can change the gearing or not. I do know that the 318 shares the same pto setup as the 420 and 430 of 2000rpm.
I can get the the rpm of these tiller at FT on my 400 if you would like.
Good luck
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 16, 2014 - 05:12 PM
Thanks for the help guys.  I let this one go.
#6 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted July 16, 2014 - 11:07 PM
how much is it selling for?
#7 Hammer OFFLINE
Hammer
  • 113 Thanks
  • 116 posts
Posted July 24, 2014 - 09:45 PM
the 318 has a 2,000 rpm pto
#8 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 25, 2014 - 09:19 PM
the seller has it on Kansas City craigs for 1500 or best offer
Edited by James henry, July 25, 2014 - 09:21 PM.
#9 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 25, 2014 - 09:21 PM
yep, had to let this one go... it would not hook up to my 318.
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted July 26, 2014 - 07:30 PM
For $1,500, you should be able to find a hydraulic tiller for the 318.
  • twostep said thank you
#11 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted July 26, 2014 - 08:26 PM
I did!  I made my usual search of craigs a week ago and lo and behold...there was a john deere 30 inch hydraulic tiller  for sale. I  went to have a look at it, and bought it.  It had the extension already bolted on it.  The guy would not part with the lift brackets.  I have a 3-point hitch on the 318, so I can use that and make my own lower brackets for it.
