Model 49 Single Stage Snow Thrower
3 replies to this topic
#1 axel waldkirch OFFLINE
axel waldkirch
  • 1 Thanks
  • 9 posts
Posted July 14, 2014 - 10:52 PM
Somewhere I had read that if you replaced the gear(s) in the side of the thrower with another one of a different size and teeth you could make it work better--- the problem is that I can not remember where I read this--- can anyone help?
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 15, 2014 - 04:12 AM
I have a 49 blower as well although I bought it used and am rebuilding it before using it.  On the large sprocket you can reduce the size. Many have gone to 34 teeth. Some go smaller but 34 seems to be the sweet spot.  I think there is a discussion on WeekendFreedommachines about this topic.
  • Trav1s and axel waldkirch have said thanks
#3 Trav1s OFFLINE
Trav1s
  • 3,571 Thanks
  • 4,544 posts
Posted July 15, 2014 - 09:27 AM
http://www.weekendfr...html?1405257813
Found this on WFM this morning.  This is one of many 49 rebuilds over there.
Edited by Trav1s, July 15, 2014 - 09:37 AM.
  • axel waldkirch said thank you
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 16, 2014 - 04:27 AM
I have the gearbox apart on mine right now. The gears are in excellent condition. It just needs the inner bearings replaced and the keys are worn in the gears. The small sprocket is worn on mine and I haven't gotten into repairing that yet.
