Where To Find New Sim / A C Parts?
6 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted July 14, 2014 - 02:58 PM
I need some spindle parts for our 60" mower deck. Does anyone know how carries parts for older A/C-Sim mower and GTs? I am looking for spindle shafts and bearings. The bearing I can match up t my local bearing house, but the hardened spindle shafts are another story.
  • 15135 Thanks
  • 15577 posts
Posted July 14, 2014 - 03:13 PM
This Spindle assembly uses needle bearings both top and bottom and the shaft is hardened to be used as the inner race. When I took the stamped steel housing out ( NOT CAST IRON) :wallbanging: , the lower bearing was all but gone and the upper shaft has a lot of wear on it and can't be re-used.
IMG_20140714_145922_533.jpg IMG_20140714_145928_498.jpg IMG_20140714_145939_264.jpg IMG_20140714_145910_875.jpg
#3 boyscout862 ONLINE
  • 15187 Thanks
  • 9998 posts
Posted July 14, 2014 - 03:18 PM
If none of our sponsors have them try the sponsors at www.Simpletractors.com. I've heard that Sandy Lake is good at finding things. When my time comes, I'll probably try making them from rod that I buy from Wholesale Tool, Surplus Center, or Bailey Sales. Good Luck, Rick
#4 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted July 14, 2014 - 06:23 PM
I work for a Simplicity dealer.  If you need parts, I can work with you.
Ben W.
#5 Bmerf OFFLINE
Bmerf
  • 1799 Thanks
  • 1466 posts
Posted July 14, 2014 - 06:54 PM
If you can't find new, could the spindle be welded up and then turned down to the proper size? Just a thought.
#6 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted July 14, 2014 - 07:50 PM
I can't weld it up because it is used as the inner race, so it has to be turned ground and polished then heat treated. After the heat treat is finished I then would have to grind and polish it to the proper OD for the bearing to ride on. I may have to turn it down and use an hardened sleeve if I can find one that will work.
  • skunkhome said thank you
#7 Talntedmrgreen OFFLINE
  • 3367 Thanks
  • 2368 posts
Posted July 15, 2014 - 06:44 AM
Hmmm...I'd try a want ad over on ST, or even your local craigslist.  You'd be amazed what you could come up with.
