Removing Hood On Deere Lt166 (Or Lt155 Or Lt133)
lt166 hood lt133 lt155 deere
3 replies to this topic
#1 myersbr2 OFFLINE
myersbr2
  • 2 Thanks
  • 2 posts
Posted July 14, 2014 - 02:57 PM
This is probably a very silly question BUT one I can't seem to find an answer to. Every mower I've had up to this point has a removable hood. However, my 2000 model LT166 doesn't seem to have an easy way to remove the hood without removing bolts. Can someone help me with this? I need to diagnose an issue with the throttle cable being stuck (always on full throttle) and having the hood out of my way to access the front of the engine would be dramatically easier.
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted July 14, 2014 - 03:06 PM
Welcome to the forum. Hopefully one of the Deere guys will be along and give you some pointers. They don't want to make them too easy, it keeps you from going back to the dealer.
#3 TAHOE OFFLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted July 14, 2014 - 03:13 PM
I've worked on both a 133 and 155, the hinge bolts are internal from what I remember, you have to take all 4 bolts off to remove hood.
I worked on a GT242 and it was same way. I had to repair it, ended up running a bolt with nut on the back through the hinge as it was busted. Maybe you can take apart and some how slot the plastic then use a bolt/nut to make just a pin hinge?
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 14, 2014 - 03:15 PM
Welcome to the forum. There are 4 bolts holding the hood on. 2 on the sides of the frame and 2 that are under the top of the frame on each side. Hope this helps
Also tagged with one or more of these keywords: lt166, hood, lt133, lt155, deere
