John Deer D100 Transaxle Parts Help
4 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted July 13, 2014 - 08:38 PM
   I am working on a friends mower.  it has a spicer transaxle model 4360-212CH and the input shaft bearings had gone bad, chewed up the top case a little.  I need to replace the bearing but JD has no part # for it on their web site and the shaft assy you can get is $120 without he bearings.
   I can get another transaxle on e-bay but it is for a L100, will it fit??  Another transaxle for the d100 new is $380.  Would like to do this as cheap as possible.
                              Pete
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 13, 2014 - 08:39 PM
Can you measure up the bearings and get something outta mcmaster carr
#3 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted July 14, 2014 - 05:24 AM
A local bearing shop should be able to help you out. Also, have you tried the trans. manufacturers site. Have a look on jdparts.com for the L100 and D100 parts diagrams and see if part numbers match for the transmission.
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted July 14, 2014 - 09:24 AM
Maybe you'll find it here:
http://www.dowdatrac...D211C0405000003
edit: oops, wrong site
Edited by jd.rasentrac, July 14, 2014 - 09:25 AM.
#5 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted July 14, 2014 - 03:02 PM
   I am going to have to go to jd for it, called the locale napa and the bearing is NLA.  got to thinking about it, $130 for the entire shaft assy isn't to bad really.  Besides it isn't my money :D   Thank's anyhow
        Pete
