Mtd 990? Need Another Set Of Eyes, Please.
128 replies to this topic
#91 Lost Pup OFFLINE
Lost Pup
  • 59 Thanks
  • 40 posts
Posted October 19, 2014 - 10:16 PM
One from a older Bolens manual.
240 in lbs which is about 20 ft lbs.
  • Moosetales and Sawdust have said thanks
#92 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted October 24, 2014 - 08:48 PM
The whole purpose of pulling the yoke off the hydro pump was to replace the fan. The fan that came off the tractor was made of metal. The only replacements I can find are plastic. Is it possible to even find metal replacement fans? Is there an advantage to going with the plastic replacement fans? I appreciate your feedback. Thanks.
Matthew
#93 Lost Pup OFFLINE
Lost Pup
  • 59 Thanks
  • 40 posts
Posted October 25, 2014 - 03:43 AM
In my review of the older manuals with pics , I have never found a metal fan only plastic.
  • Moosetales said thank you
#94 VTXrider OFFLINE
VTXrider
  • 516 Thanks
  • 375 posts
Posted October 25, 2014 - 03:50 AM
Never came across a metal fan. The plastic units are about $25 and the spring retaining ring is what holds it onto the yoke.
#95 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 25, 2014 - 06:08 AM
Now I'm intrigued as to what brand my metal fan came off of. The metal fan was held on by a small bolt which acted like a set screw. I've seen several fans with seemingly different set ups. Any chance you have a pic of what you are referring to when you say "retaining ring"? Thanks.
#96 Lost Pup OFFLINE
Lost Pup
  • 59 Thanks
  • 40 posts
Posted October 25, 2014 - 07:03 AM
I have seen both styles.
Pics from the manuals below.
#97 Lost Pup OFFLINE
Lost Pup
  • 59 Thanks
  • 40 posts
Posted October 25, 2014 - 07:08 AM
The fan is fastened / held by compression by use of the retaining clip.
#105 in the third pic. I will search my actual pics to see if I have a clear one.
Of course it's not as secure as the bolt thru.
#98 Lost Pup OFFLINE
Lost Pup
  • 59 Thanks
  • 40 posts
Posted October 25, 2014 - 07:31 AM
Actual MTD 990 Pic
Needed a custom puller to remove the driveshaft yoke.
The other side of the fan is sectioned/divided so with the clip on it
compresses/holds it to the yoke to rotate.
#99 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 25, 2014 - 03:28 PM
Before I break something I thought I'd ask how you guys have gotten the bottom bracket bolt for the generator off without busting something?
Thanks.
#100 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted October 25, 2014 - 06:43 PM
Here's a pick of my plastic fan before I took it off. I don't remember having any problems with the S/G bracket. I do remember taking the S/G off first then the bracket.
Here is the only pic I have of the S/G.
#101 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 25, 2014 - 07:34 PM
Here's the bolt I was referring too.
(Sorry the pic is turned. I am posting from my phone and nothing seems to be working as expected. Ugh.)
(after)
(before)
I solved the problem by removing all four motor mounts and sliding the motor far enough to where I could get a wrench on it.
With the removal of the engine mount bolts and a few more parts I am definitely going to need your help putting the 990 back together. I am doing well not to freak out about where all the parts will go.
Edited by Moosetales, October 25, 2014 - 07:38 PM.
#102 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted October 25, 2014 - 10:26 PM
Glad you got that off without any damage. My pics in sequence as I took things apart has helped me a great deal. Don't take too much apart without taking pics. Even though I bagged all the hardware & marked them I forgot some of my own terminology. The next time I'll mark things according to the manual.
#103 VTXrider OFFLINE
VTXrider
  • 516 Thanks
  • 375 posts
Posted October 26, 2014 - 03:04 AM
It comes apart fast but going back together takes longer than my short memory. I know you don't have the option I did but having an assembled 990 to go look at, is how I remembered. If you need help, I can take pictures any time to post for you. I have quite a few pictures to refer back as does Lost Pup and Sawdust. Lost Pup's detailed rebuild has helped me in the past.
I have been cleaning a lot of rusty tools and parts lately. I use white vinegar to soak them in for 24 hours. Rinsing and wipe the black coating off. Wire brush or use a green scrubbing pad if needed then coat with oil. Works good with bolts and nuts. All these tools were rusty and they turned out nice.
Edited by VTXrider, October 26, 2014 - 03:12 AM.
#104 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 26, 2014 - 06:44 AM
Looking great. Almost a black oxide appearance. I really like that gun metal Grey appearance.
  • Sawdust said thank you
#105 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted October 26, 2014 - 06:08 PM
Don't worry.  Rule of thumb is you can leave off / forget 5% of the parts before you will have any trouble. :thumbs:
  • Moosetales and VTXrider have said thanks
