Running Like Crap
14 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 12, 2014 - 04:50 PM
The 990 started running rough and died. Did a little investigating and found this...
Never had a carb fall off while mowing lol.
  • T Guiles said thank you
#2 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 12, 2014 - 06:15 PM
At least its a simple fix!!
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 12, 2014 - 06:28 PM
The plug missing by the filter still be harder.
#4 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted July 12, 2014 - 06:40 PM
It's a welch plug.  You may be able to match it up at a parts store.  Just measure the indented hole.  The correct plug will just slip into it.  Then you ping a dent into the plug's center to lock it in place.
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 12, 2014 - 06:43 PM
I thought that. I wonder how long it's been missing and I just haven't noticed it.
#6 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted July 12, 2014 - 06:45 PM
You know, you might find one of those expanding rubber engine frost plugs that will fit in there.  Long as she's plugged, it doesn't matter what you use.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 12, 2014 - 07:20 PM
 Both bolts are backed off so it must have been hanging there and then vibration or a sudden bump must have caused it to fall off. That's a pretty crude kill switch!
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 12, 2014 - 07:45 PM
Wow, those bolts were loose!
I have those welch plugs in stock. They are a bit thinner than your average welch plug.
Ben W.
  • MH81, Alc and boyscout862 have said thanks
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted July 12, 2014 - 11:15 PM
Just maybe don't use a rag though... :smilewink:
#10 MH81 OFFLINE
Posted July 12, 2014 - 11:21 PM
"We'll, here's your problem, right here!"
Never seen one fall off like that, how the heck was it running at all?
I get the "like crap" symptom with a little play in the throttle shaft, you've got a 1/4" chasm.
#11 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted July 13, 2014 - 01:53 AM
Yup that would do it,you might be running a little lean......I'm glad it will be an easy fix for you  :thumbs:
#12 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,457 Thanks
  • 5,765 posts
Posted July 13, 2014 - 02:52 AM
Those Zenith carbs are pretty straight forward..  Hope ya get it fixed in short order!
#13 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted July 13, 2014 - 07:44 AM
thats what my dad used years ago, ran for yrs with one
#14 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 13, 2014 - 08:17 AM
I ran like this until I shut it off. It wouldn't start back. It's missing half the gasket. Hopefully it fell out and didn't get sucked up the intake.
#15 SammyRye OFFLINE
SammyRye
  • 41 Thanks
  • 45 posts
Posted July 19, 2014 - 05:14 PM
Had that very same thing happen - the bolts just vibrated loose!  Lock washers fixed that.  The welsh plugs are available - one comes with a carb rebuild kit.
WNYTractorTinker - you mentioned a Zenith carb - I thought these were made by Walbro?
Rich
  • VTXrider said thank you
