John Deere 111 Engine Swap
11 hp briggs 8 hp briggs john deere 111
9 replies to this topic
#1 magneto1963 OFFLINE
magneto1963
  • 6 Thanks
  • 14 posts
Posted July 12, 2014 - 01:14 PM
just picked a 1982 jd 111 with an 11 hp briggs,the guy said he was cutting his lawn and it stopped very suddenly,he thought he seized the motor.the motor wouldn't budge so I got hammer and chunk of wood and got it loosend up,but still very hard to turn. it takes a huge effort to turn the fly wheel and that's by both hands with the plug out.the pistons moving in and out so cant be the connecting rod,or ?  anyway I also have an 8 hp briggs from a 78 craftsman, does any body know if I can swap the 8 hp  for the 11 hp without any problems ? thanks.
Edited by magneto1963, July 12, 2014 - 02:57 PM.
#2 magneto1963 OFFLINE
magneto1963
  • 6 Thanks
  • 14 posts
Posted July 12, 2014 - 02:55 PM
so iv been playing with the seized 11 horse briggs,sprayed a lil 2 stroke mix in the cylinder and have been working it back and forth,its  getting a lot looser now, the starter will even turn it now but very slowly :thumbs:
#3 Trav1s ONLINE
Trav1s
  • 3,512 Thanks
  • 4,493 posts
Posted July 12, 2014 - 03:28 PM
If you can turn the engine so the piston is up, pour ATF on top of the piston and leave it sit overnight.
  • magneto1963 said thank you
#4 magneto1963 OFFLINE
magneto1963
  • 6 Thanks
  • 14 posts
Posted July 12, 2014 - 03:58 PM
I will try that, thanks.
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 12, 2014 - 06:54 PM
Could have been ran low on oil and locked up
#6 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 12, 2014 - 07:48 PM
If I was you, I'd make an effort to pull the oil pan off and check your rod.
It sounds like your rod was frozen to the crank.
Don't try to run it like that, you'll risk blowing the rod through the side of the engine.
Ben W.
  • trowel and magneto1963 have said thanks
#7 magneto1963 OFFLINE
magneto1963
  • 6 Thanks
  • 14 posts
Posted July 12, 2014 - 08:09 PM
thanks ben,i actually had running for about a half hour before I seen your post,seems to be running fine.do you think its ok now ? or would you still tear it down
 ? thanks
Edited by magneto1963, July 13, 2014 - 04:23 PM.
#8 magneto1963 OFFLINE
magneto1963
  • 6 Thanks
  • 14 posts
Posted July 15, 2014 - 01:22 PM
well I never ended up tearing it down but two days and two lawns later, still running like a champ.
#9 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted July 15, 2014 - 05:50 PM
Sometimes we get lucky.   :smilewink:
#10 Modeere318 OFFLINE
Modeere318
  • 2 Thanks
  • 1 posts
Posted July 20, 2014 - 12:51 PM
It seems that you corrected the problem even if accidentally by adding all that oil.  If it was me I would keep a close check on the oil.  It might last for years and serve you well.
I am a different kind of person than you.  I would have spent considerable time searching post until I was sure of the problem.  But then my luck quotient is very low.  I hardly win at the game of chance.
  • HDWildBill and magneto1963 have said thanks
