A/c 917H Electrical Issues
9 replies to this topic
#1 Browncoat OFFLINE
Browncoat
  • 4 Thanks
  • 6 posts
Posted July 10, 2014 - 01:48 PM
Greetings everyone, this is my 1st post here.
I own an A/C 917 Hydro that was given to me by my father. He's owned A/C garden tractors ever since I can remember, and has had several restoration projects go through the garage. This particular tractor was purchased to cannibalize parts from, but when my John Deere mower bit the dust, he gave it to me. There are a few cosmetic issues, and the mower deck needs some work...but it's mechanically sound and runs great. With one exception...
I'm having issues keeping the battery charged.
I recently replaced the battery and voltage regulator, but I'm still not seeing a positive reading on the ammeter to indicate that the battery is charging. I can jump start it just fine, though.
Any thoughts on where to look next?
  • VintageIronCollector said thank you
#2 Bolens 1000 OFFLINE
  • 14,810 Thanks
  • 18,058 posts
Posted July 10, 2014 - 02:16 PM
Werlcome to the Forum!
What kind of starter does this have? I assume the common delco remy starter/generator?
If so have you inspected that? The regulator only controls how much voltage goes back to the battery, the starter ultimately charges your battery.
  • Browncoat said thank you
#3 Browncoat OFFLINE
Browncoat
  • 4 Thanks
  • 6 posts
Posted July 10, 2014 - 02:31 PM
As far as I can tell, yes. It has a standard starter/generator...and no, I haven't inspected it. At least that gives me someplace to start.
Electrical systems are definitely not my forte.
#4 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted July 10, 2014 - 09:08 PM
What engine do you have in that tractor? None of the Allis Chalmers large frame tractors produced after 1971 had Starter/Generators. The KT17 supplied with the tractor would have a geared starter and stator under the cowl.
#5 Browncoat OFFLINE
Browncoat
  • 4 Thanks
  • 6 posts
Posted July 11, 2014 - 09:31 AM
It's not the original engine, for sure. I remember my dad pulled it. I'll have to check.
#6 HDWildBill OFFLINE
  • 8,972 Thanks
Posted July 11, 2014 - 09:57 AM
Welcome to GTtalk.  If you can provide the brand and model # of the engine that will help pin down where the problem is.
#7 Browncoat OFFLINE
Browncoat
  • 4 Thanks
  • 6 posts
Posted July 11, 2014 - 10:35 AM
Briggs & Stratton 326437-0649-01
16HP single stroke
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,195 Thanks
  • 5,795 posts
Posted July 11, 2014 - 11:11 AM
:welcometogttalk:
#9 HDWildBill OFFLINE
  • 8,972 Thanks
Posted July 11, 2014 - 01:24 PM
You have an alternator,  Since this is not the OEM Engine then I would check the wiring and make sure it is correct.  Also you may need to put a different regulator on there since the OEM had a starter/generator.
#10 VintageIronCollector ONLINE
    Immersed in Tractors
  • 1,406 Thanks
  • 1,853 posts
Posted July 11, 2014 - 01:39 PM
The original engine had the alternator type started on it not a S/G so it should be fine
  • HDWildBill said thank you
