New Fuel Pumps For My Onans!
20 replies to this topic
#1 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 09, 2014 - 07:41 PM
Last week I ordered 3 of these for my Onan engines. I am tired of cranking for several minutes waiting for the vacuum pumps to draw fuel up!
knew item  12 volts  THIS IS A UNIVERSAL FUEL PUMP FOR MARINE,DIESEL,TRUCKS,CARBURATED CARS,JEEPS.
I SOLD MANY OF THESE PUMPS FOR FOR GENERATORS,RIDDING TRACTORS,HYDROGEN PROJECTS,DIESEL PRIMING,BOOSTER OR REPLACING MECHANICAL PUMPS.NO DIAPHRAM.I HAVE MANY OF THESE PUMPS AND DIFFERENT KIND THAT MIGHT MEET YOUR APPLICATION.IF INTERESTED IN MORE THAN ONE I WILL ADD $2.00 EXTRA  FOR COMBINING SHIPPING.THEY ARE 12 VOLTS 1/4 TUBING IN AND OUT 18 to 20 GPH FREE FLOW PLEASE LOOK AT MY OTHER LISTING UNDER  LOW PRESSURE FUEL PUMPS AND SEE OTHERS.THIS PUMP IS A FREE FLOW  the solenoid pump uses a piston actuated by an electromagnetic coil to generate fuel pressure and flow. By using only short pulses of electricity, the solenoid pump is very energy-efficient. It is also long-lasting, with no internal rubber parts or bellows to wear out.
1 TO 3 PSI SHUT OFF PRESSURE
1/4 TUBING IN AND AND OUT
WIDE OPEN  FLOW 18 TO 20 GPH
INTERCHANGE APPLICATION
Got them today and will be installing this weekend.
  • olcowhand, MH81, Alc and 4 others have said thanks
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 09, 2014 - 07:48 PM
Looks like it should do the trick. Keep us informed. And what no pictures?
#3 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 09, 2014 - 07:59 PM
I'm just too d******* tired to do all that! You get pics as I install one!
I spent the after work time getting guttering ready to hang!
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 09, 2014 - 08:10 PM
Take it easy big fella. I am was very interested in the pump, but no link to look at. Seems to be the thing I needed for the bobcat, but just bought a new mechanical pump for the four cylinder Ford motor. Looks to be a direct fit, only $106 list, they gave me a discount; only $86 plus tax. Oh well the old one only lasted about 35+ years.
#5 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 09, 2014 - 08:34 PM
Sorry if I came across harsh! Just been a tiring week thus far! I sale has ended on epay, so a link wouldn't work. Maybe I can find a way to link to the pumps elsewhere!
  • Bmerf said thank you
#6 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 09, 2014 - 09:05 PM
No problem. I understand about tiring weeks. Today was my weekend. Monday is my next day off.
Pump is relisted:
http://www.ebay.com/...4158781?vxp=mtr
Now no hurry, when you get it installed., Please write a review.
#7 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 10, 2014 - 05:45 AM
I'll work up some pics of it and we'll see how it works. They are bigger than I thought they would be, the pump body is 2" dia.
#8 MH81 OFFLINE
Posted July 10, 2014 - 05:54 AM
Sounds like a nice upgrade.
Hope they work just like you want
#9 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 10, 2014 - 07:02 AM
I hope so too! I bought one from NAPA a while back and it works when it feels like it. Checked all electrical connections and should work.
I took a pic of one this morning, Had my paw in there so you can get an idea of size.
The mounting holes are for 1/4" bolts, spaced about 2-5/8" +/- apart. Overall length is about 6".
Edited by KennyP, July 10, 2014 - 07:03 AM.
Added length
  • olcowhand and Alc have said thanks
#10 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 14, 2014 - 05:10 AM
I finally found time to get the new pump installed. I put it under the frame as it will always have fuel to it. I had hoped to tuck up above the bottom, but too much in the way for that. Had an issue with water in the bowl since this has sat for a bit. I put a bit of Seafoam in the tank to help with that. Once the water cleared out, everything was fine. No more cranking away waiting for the fuel to get there.
  • olcowhand, MH81, Alc and 1 other said thanks
#11 olcowhand OFFLINE
  • 41,092 Thanks
  • 31,402 posts
Posted July 14, 2014 - 08:16 AM
Yes, electric is king!  Once a tractor has sat several days, the fuel in the carb evaporates, causing LONG cranking times with vacuum pulse pumps.
#12 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted July 14, 2014 - 01:54 PM
Kenny, how much did one of these cost??
Do you think this pump will work on the Onan P220?? Or even the newer 20hp Kohler ?
Edited by victor3ranger, July 14, 2014 - 01:57 PM.
#13 olcowhand OFFLINE
  • 41,092 Thanks
  • 31,402 posts
Posted July 14, 2014 - 02:12 PM
They will work on pretty much any engine.  The key is in the low psi output.
#14 MH81 OFFLINE
Posted July 14, 2014 - 05:04 PM
Looks nice Kenny,
Glad it's working as advertised.
#15 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 14, 2014 - 06:43 PM
:ditto:
