420 Jd?
9 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,131 Thanks
  • 10,199 posts
Posted July 09, 2014 - 03:36 PM
     Back when, at least 15 years ago, the Illinois Tollway had JD GTs to mow the oasis and toll areas. They had a lot of trouble with them. Of the 12 tractors, 11 had issues with valve seats coming out.
     These were a 420 model and I was told they had Briggs twin engines. I was just looking this up on TractorData and they said it had an Onan engine.
     Is anyone familiar with any of this?
#2 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted July 09, 2014 - 04:31 PM
They have onan engines. They must've been repowered 420s they were using.
  • LilysDad said thank you
#3 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted July 09, 2014 - 04:55 PM
Wonder why Briggs?
Edited by Trav1s, July 09, 2014 - 04:56 PM.
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,131 Thanks
  • 10,199 posts
Posted July 09, 2014 - 05:47 PM
They were bought new. Did JD have another model with Briggs twins? Did Onan have a valve seat issue?
#5 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted July 09, 2014 - 07:15 PM
Onan have valve seat issues.
Especially the cylinder closest to the driver.
Joe
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted July 09, 2014 - 08:53 PM
During that era, the only JD with a Briggs was the least expensive LT models.
#7 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted July 15, 2014 - 07:02 PM
LOL go figure !  No valve seat issues with ANY of the Briggs engines that I have.  Loves me the old L series opposed twins.  They just run and run and run and....   :worshippy1:
#8 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted July 15, 2014 - 07:44 PM
I've had at least a dozen Onan engines, and never had a valve seat issue with any of them.  In that same time frame, I've had at least 2 Briggs with floating valve seats.
  • dave8338 and LilysDad have said thanks
#9 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted July 15, 2014 - 07:57 PM
EXACTLY ! !  I think it has more to do with "the luck of the draw".   :thumbs:
#10 DeadDeere420 OFFLINE
DeadDeere420
  • 1 Thanks
  • 1 posts
Posted July 19, 2014 - 06:00 PM
I have a 420 and it came factory with the Onan P220g
I have had a valve seat go on the original block at about 1100 hours
The valve seats go when the engines aren't cared for properly
I was guilty of not keeping the cooling fins clean and I learned my lesson
If you have a 420 there are a couple of things that can be done to help prevent this
1) don't use gas with ethanol (ethanol cause problems with feul lines and carbs potentially leaning of the mixture)
2) Make sure you have the insulation sheet that goes on the firewall. This forces air flow through flywheel screen and under the engine shrouds
3) Use the Onan oil filter seal. It closes off a potential leak area between the filter and the sheet metal. This ios why the right side is the most common to fail
4) keep the cooling fins clean. I now use air pressure to blow the dirt and dust out of them
The Onan's are like any other engine. When properly maintained, they last. I didn't keep mine clean and I paid for it
  • Rock farmer said thank you
