Removing Stripped Alen Nut"?
19 replies to this topic
#1 ranchruler@yahoo.com OFFLINE
  • 17 Thanks
  • 44 posts
Posted July 09, 2014 - 09:41 AM
how do you remove a stipped allen nut then is down inside of a pulley.
  • VintageIronCollector said thank you
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted July 09, 2014 - 10:08 AM
I would try putting some lubricant on it if it's rusty and letting it set about a week or so. Some people weld metal on to the tops of bolts when they are stripped and you might be able to do the same thing here but I'm not positive because I've never tried it before. Maybe you could even use a very strong epoxy like JB Weld if it's down in too far to weld it. Wait and see what other people recommend first because I am not totally sure.
#3 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted July 09, 2014 - 10:32 AM
Would you be able to grind an easy-out to fit ?
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 09, 2014 - 10:49 AM
Got any pictures. Without seeing it I'd say try to drill it out, starting with a small bit and working up to one that just clears the sides of the threads in the pulley.
#5 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted July 09, 2014 - 11:18 AM
I have had to drill them out before.  They pretty much self-align the bit, being there is already a centered hole in the allen set screw.  Whatever size allen that's in there, find the size tapping drill bit for that size.  It will take out the allen, l;eaving only it's threads in the pulley threads.  Once drilled out, remove the pulley, then chase the threads with appropriate tap.
  By the way, just put the drill bit down to the side of the pulley flange touching the shaft, then put a piece of tape on the drill at the top edge of the flange on the drill so you will know how deep to drill.
  • Texas Deere and Horse, hamman, sacsr and 4 others have said thanks
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,343 Thanks
  • 9,800 posts
Posted July 09, 2014 - 11:55 AM
Those allen screws are usually pretty hard. I tend to strip the allen wrench first. Someone on here(Nato77? or maybe glgrumpy?) just used a dremel grinder to grind through a stripped screw.
#7 Sawdust ONLINE
Sawdust
  • 5,680 Thanks
  • 3,381 posts
Posted July 09, 2014 - 12:53 PM
I've always used Olcowhands method with good success. Let us know how you do with pics  :D
#8 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted July 09, 2014 - 01:25 PM
I've used a torx bit before to remove a stripped allen head bolt. Sometimes you might have to tap it down into it pretty hard to get it to grab. Lots of penetrating oil and time always helps.
  • sacsr and LilysDad have said thanks
#9 HANKG ONLINE
HANKG
  • 6,324 Thanks
  • 3,427 posts
Posted July 09, 2014 - 02:52 PM
Just replaced all bearings in my simplicity deck three allens were stripped on pulley's the above advise is spot on get yourself a couple of good hard bits and have at it use a little wd40 to cool your last bit size should be just under 1/4 follow up with 1/4 inch tap
  • olcowhand said thank you
#10 Traill95 ONLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted July 09, 2014 - 07:40 PM
I spent over thirty years in maintenance shops and this is the best method. :thumbs:
#11 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted July 09, 2014 - 07:45 PM
Never heard of an 'allen nut' before!
#12 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted July 09, 2014 - 08:01 PM
Left-hand spiral drill bits in a reversible drill work great.
Often the heat created while drilling, plus the "un-screwing" rotation, will unscrew the set screw without having to drill all the way through.
  • olcowhand and Texas Deere and Horse have said thanks
#13 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted July 09, 2014 - 08:04 PM
I haven't either, but know a guy named Alan that's quite the "nut"
:rolling: :rolling: :rolling: :rolling: :rolling:
  • olcowhand, MH81 and KennyP have said thanks
#14 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted July 09, 2014 - 08:07 PM
I think that is more like a 'nutcase'! Anyway, I know what allen bolts are. Just haven't ever in 45 years heard of an allen nut!
#15 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
In the 40+ years of working in machine/ fabrication shops, we have had great success with both of these methods.
