Free Is Fine With Me.
19 replies to this topic
#1 alleyyooper OFFLINE
alleyyooper
  • 945 Thanks
  • 420 posts
Posted July 09, 2014 - 07:04 AM
Free is fine with me but what is it.
Decal says wheel horse and has a 7 HP Kohler engine under the fuel tank. Guy gave it to me when it stopped running. I found it doesn't have any spark. I figure a tune up set of points and condenser will get it running.
:D   Al
  • Alc, hamman, Titus and 8 others have said thanks
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 09, 2014 - 07:45 AM
Those are pretty desirable among the Wheel horse guys.  I've gotten freebies before but never anything like that.  I'm not sure if it's an RJ or a Suburban or what the difference even is (not up on these models like I would like to be).  Either way, it's a great gift!
  • tinbender7 said thank you
#3 panzersarebest OFFLINE
panzersarebest
  • 523 Thanks
  • 407 posts
Posted July 09, 2014 - 07:50 AM
I think what you have is a Wheel Horse RJ58, or a Suburban 400, which should have a 4 HP Kohler engine, witch is what engine looks to be on it now.
http://www.angelfire...rsehistory.html
#4 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted July 09, 2014 - 07:55 AM
Its a suburban, With a K91/4hp engine. These are great little tractors.
#5 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted July 09, 2014 - 08:08 AM
Yep! You have desireable "Ball Burner" tractor! Looks quite complete for age, many are cobbled up by now. That little K engine is so cute! Wonder if hard to find those engine parts? I've only seen one at a Horse swap-meet once and was incomplete, but cute! Guess the other guy's know the models better and have put in info. They had later ones with bigger engines in same place, even some Clintons (Uck!) but moved up front later in years. Good idea! Ha!
#6 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted July 09, 2014 - 08:28 AM
Congratulations on a great toy and at the perfect price. Do be carefull with that nut roaster. Parts are available for the K91 engine. I have one on my old Bolens Leaf vacuum. Good Luck, Rick
Edited by boyscout862, July 09, 2014 - 08:30 AM.
#7 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted July 09, 2014 - 09:40 AM
Push-pull choke and throttle make it a 1961 model.
The 4hp model 401 manual start used a 3-piece transmission case - cast iron center section with plate steel side plates.
The 5.5hp model 551 electric start used a 2-piece transmission case that continued till the end in 2007.
Garry
  • sacsr said thank you
#8 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted July 09, 2014 - 11:24 AM
That's a great freebie!!!!!!!!!!
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,292 posts
Posted July 09, 2014 - 11:44 AM
fine tyres!
#10 KC9KAS ONLINE
KC9KAS
  • 5,444 Thanks
  • 4,712 posts
Posted July 09, 2014 - 12:36 PM
You lucky dog!
Finding one of these is one thing, but for free!
#11 Sawdust OFFLINE
Sawdust
  • 6,010 Thanks
  • 3,490 posts
Posted July 09, 2014 - 12:55 PM
That's nice congrats to you for free!
#12 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 09, 2014 - 01:22 PM
I like those model wheel horses
#13 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 09, 2014 - 05:11 PM
:cowboy_shooter:
What do you mean, "uck!"?
Ben W.
  • trowel said thank you
#14 MH81 OFFLINE
Posted July 09, 2014 - 05:49 PM
Wow, congrats.
Very nice little WH, and like said above... At the perfect price.
#15 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted July 10, 2014 - 07:33 AM
Are you going to restore it? I restored the one i had. http://gardentractor...s.blogspot.com/
