Help With A/c 416 Hydro Problem
a/c 416
5 replies to this topic
#1 ibnav8r OFFLINE
ibnav8r
  • 4 posts
Posted July 08, 2014 - 11:17 PM
I have an A/C 416 Hydro that will go when the transmission selector is advanced to slow, but if I try to advance it to a faster speed it acts like there is resistance and it will kill the engine. Does anybody have an idea what could cause this? It was working fine and just started doing this while mowing the yard. The transmission reservoir is full of fluid.
#2 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted July 09, 2014 - 06:59 AM
I get something similar on my HB112 hydro when my plow gets stuck on a root.  You just can't push hard enough to get more power to the wheels.  I think it has to do with back pressure in the system.  If your's does it with no load, I would be looking at the gearbox oil levels & axles.  Jack the rear end & spin the tires.  Do they move freely or not at all?
Edit: That or stuck brakes.
Edited by New.Canadian.DB.Owner, July 09, 2014 - 07:00 AM.
  • ibnav8r said thank you
#3 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted July 09, 2014 - 08:10 PM
Could there be a restriction in the return on the hydro motor that won't allow that volume of oil through? Does it try to stall the engine in reverse as well?
#4 ibnav8r OFFLINE
ibnav8r
  • 4 posts
Posted July 14, 2014 - 10:23 PM
Thanks for your suggestions.
I jacked it up and turned the tires to check out the differential, that all seemed to work properly without much drag. I opened up the reservoir and looked closer at the fluid. It looks like strawberry milk. I suspect there is moisture in the hydraulic fluid and the filter would not allow it through. I drained the fluid and am in the process of flushing out all the old fluid to put new DEXRON in as recommended in the operator's manual. Now the problem I'm having is to find a replacement filter. I get the shoulder shrug from everybody I try. The Allis Chalmers part number is 2027483. Does anybody know where I can order one of these filters?
#5 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted July 15, 2014 - 02:10 PM
If it is a Vickers with the external reservoir, a Napa 1467 will work.
  • olcowhand said thank you
#6 olcowhand ONLINE
  • 42,322 Thanks
  • 31,779 posts
Posted July 15, 2014 - 03:37 PM
Yes, it should be a Vickers.
Also tagged with one or more of these keywords: a/c 416
