How often do you sharpen your blades?
24 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted March 01, 2010 - 08:20 AM
I was curious to see how often everyone else sharpens their mower blades during the mowing season. I seem to usually be able to get away with only once a year as long as I don't hit anything LOL. I have been debating doing it twice a year but I haven't decided yet or not.
I always sharpen my blades myself and have never had a problem doing so. I would like to write a little how to on doing it yourself but haven't had time to do it yet.
#2 massey driver ONLINE
massey driver
  • 1,484 Thanks
  • 1,592 posts
Posted March 01, 2010 - 08:57 AM
Usually every spring before mowing season and then it's just to take the bigger nicks out.I don't put a sharp edge on just make sure there balanced as good as I can get them. Over the course of the summer they take lots of abuse.I have lots of trails to cut and meadows plus the lawn.Dug as many of the big rocks out as I could and hopefully will do more this year.These are a bit hard on the baldes .LOL Larry:D
#3 Bolens 1000 ONLINE
  • 15,300 Thanks
  • 18,236 posts
Posted March 01, 2010 - 10:45 AM
I sharpen my blades once a season. More if I end up hitting anything LOL.
I sharpen mine on the bench grinder
#4 poncho62 ONLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted March 01, 2010 - 10:57 AM
Every spring.........use a angle grinder and don't make them too sharp. I use the mower to windrow leaves in the fall, so they are pretty beat up when I put it away for the winter.......I bought new blades for my lawn tractor last fall. The old ones were real torn up.
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,380 Thanks
  • 5,611 posts
Posted March 01, 2010 - 08:07 PM
2 maybe 3 times a year. I run a Ransome 3 wheeler, it's the main grass cutter, 18hp 60" cut, in the spring when grass is heavy I cut once a week and it takes me 6 hrs. non stop to cut everything once. I love the look of a large wide open lawn with a few trees in it.
#6 olcowhand ONLINE
  • 42,520 Thanks
  • 31,838 posts
Posted March 01, 2010 - 08:44 PM
At least once, usually twice...more if I try to mow a piece of farm equipment! LOL
#7 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted March 01, 2010 - 10:48 PM
You mean you have to sharpen them? I thought they were lifetime blades, hehehe
#8 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted March 02, 2010 - 08:46 AM
2 or 3 times a year in the past. put gator blades on late last summer, looking forward to see how they do in thick spring grass.
#9 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 03, 2010 - 06:03 PM
Just once a year. I have found that they were not too bad even after a year. I put about 3 hours a week on my LT during mowing season. I use an angle grinder, the blades twist and curve too much to use the bench grinder.
#10 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 16, 2011 - 08:28 AM
With a little blushing, I have to admit that I have never tried to sharpen blades before. I usually just buy new ones or deal with bent grass. HA!
#11 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted February 17, 2011 - 01:12 AM
I do mine as needed. I check them as part of the preflight routine. Usually end up needing a touchup every other or every third mowing.
I was told by a pro once to keep them sharp enugh to cut instead of tear, following that advice I found the yard looks better, holds up better during dry spells, and most importantly to me with the same hight grass using the same gear I will use less gas with sharp blades.
And as with any tool, touchups are a lot easier than refurbishing, and if it turns colors when your grinding...well you just destroyed it...
More on that when the topic comes up.
#12 mjodrey OFFLINE
Posted February 17, 2011 - 05:29 AM
As old as this thread is,I just found it.I usually sharpen me blades about3 times a year.
#13 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 17, 2011 - 05:44 AM
Looks like I better fire up the bench grinder!
#14 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,676 Thanks
  • 5,052 posts
Posted February 17, 2011 - 07:47 AM
I generally sharpen twice a year. The first time is just after the first mow of the season.
#15 josh deaven ONLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted February 17, 2011 - 10:55 AM
I sharpen mine every 8hrs.
