Newby Needs Help With 12.5 Tecumseh Governor Linkage
4 replies to this topic
#1 weewillie OFFLINE
weewillie
  • 1 posts
Posted July 07, 2014 - 03:53 PM
need to know if this is correct
#2 boyscout862 OFFLINE
  • 10,040 Thanks
  • 7,670 posts
Posted July 07, 2014 - 04:49 PM
Welcome to GTT. Check in our Manuals Section for the correct manual. You can download 3 for free per day. Good Luck, Rick
#3 New.Canadian.DB.Owner OFFLINE
  • 2,254 Thanks
  • 1,464 posts
Posted July 07, 2014 - 06:40 PM
I am going to take a stab in the dark & say NO!  At a minimum, the throttle cable & choke cables have no end clamps, so moving the lever won't move the fly, it will just shorted the amount of solid wire sticking out the end of the shielding.  Secondly, those cables rarely get attached to a place with a rubber bushing.  Those are normally for governor rods & springs so they stay firm.  The throttle cable should be attached to the mechanism on the right side of your first photo.
Edit: Found a photo in my archives:
Edited by New.Canadian.DB.Owner, July 07, 2014 - 06:46 PM.
  • Gtractor and weewillie have said thanks
#4 TomLGT195 OFFLINE
TomLGT195
  • 2,904 Thanks
  • 2,267 posts
Posted July 07, 2014 - 07:18 PM
Sorry I'm no help , but WELCOME to GT talk. There are lotsa guys who can help ,be patient they'll be here soon . Pics of the tractor would be cool too.
Edited by TomLGT195, July 07, 2014 - 07:18 PM.
#5 TAHOE OFFLINE
TAHOE
  • 6,595 Thanks
  • 5,017 posts
Posted July 08, 2014 - 08:54 AM
Welcome
I have to agree with Canadian, the throttle cable should be attached to the attached tot he plate mechanism on the side of the motor.
The governor linkage should then attach to the rear butterfly wit the red rubber grommet. The butterfly with the plastic lever on top is your choke, the choke is almost always toward the outside of carb.
  • weewillie said thank you
