1966 Jac 800 Won't Charge
15 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted July 07, 2014 - 09:04 AM
Can anyone here take some pictures of a Jacobsen 8hp with push button start? I need some pictures of the wires on the voltage regulator and where they go to. Mine doesn't have one on the bottom one and I'm not sure if thats my problem or not. Thanks in advance
#2 boyscout862 OFFLINE
  • 13,437 Thanks
  • 9,384 posts
Posted July 07, 2014 - 10:07 AM
Try our Manuals Section there are alot of Ford/Jacobsen manuals. If its a Kohler engine, a Kohler manual may have the answer. Good Luck, Rick
  • VintageIronCollector said thank you
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,013 Thanks
  • 5,978 posts
Posted July 07, 2014 - 01:23 PM
Not that I'm a Jacobson aficionado the charging wire from the regulator will travel to the amp meter if there is one.  In one side and charging wire will travel onward..(An in series connection if you are electrically oriented)
It will leave the other side of the meter and go to the Run side/terminal of the key switch.  It needs to be isolated when the key is off or it will drain the battery.
Hope this helps..
  • boyscout862 and VintageIronCollector have said thanks
#4 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 08, 2014 - 08:21 AM
Vintage
Try this page..  I found it helpful when partially rewiring my 66 Jac Chief 1000
http://www.farmallcu...stem Checks.pdf
How to test an ammeter
http://www.yesterday...ll&th=130765%3E
Starter/Gen wiring on a cub cadet
http://www.ihcubcade...106/169489.html
Mike
#5 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 08, 2014 - 01:42 PM
Vintage
It looks like the bottom connector on my VR goes to the Armature post of the generator. I'm not sure what label is on the bottom tab of my VR.
mike
#6 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 08, 2014 - 03:54 PM
Vintage
mike
Thanks for the pictures very helpful but could you get a picture that shows the terminals on the VR a little better? Also do you have a wire coming from behind the VR?
  • Mike125s said thank you
#7 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 08, 2014 - 05:16 PM
Vintage
Top of VR is field
Middle post is Batt
Bottom is l(Load??)
Bottom l is not connected to anything. Wire from back is probably the ground wire(G)
Good luck
I went through wire by wire to reconnect the ammeter and make sure the other wires went to the right places. I can't get a pic any closer to the VR
Sorry VR pic is upside down.  Had to do that to fit my ipad mini in there
Mike
Edited by Mike125s, July 08, 2014 - 05:18 PM.
#8 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 08, 2014 - 06:14 PM
Vintage
Top of VR is field
Middle post is Batt
Bottom is l(Load??)
Good luck
Mike
My wiring is not at all like yours. Did you rewire yours?
#9 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 08, 2014 - 06:30 PM
Yes I had to rewire mine,as the previous owner had bypassed the ammeter .  I went wire by wire by following various diagrams for tractor starter/generator systems(Like the cub cadet one above).  Mine works well now , charges the battery,and the ammeter works now too
Mike
#10 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 08, 2014 - 06:37 PM
Mike
I might end up rewiring mine like yours but I'll look over mine again.
#11 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 08, 2014 - 06:55 PM
By the way, L(Load) terminal on the voltage regulator is for lights(I think)
Mike
#12 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 09, 2014 - 09:56 AM
I'm going to check over mine to make sure that mine works but the VR or the ammeter is the problem.
#13 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 09, 2014 - 06:34 PM
http://www.amazon.co...#productDetails
Would this work on my 800?
#14 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 10, 2014 - 05:57 AM
I don't know. How did you determine the VR is bad
#15 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted July 10, 2014 - 06:31 AM
The internal connections are corroded and terminals are rusty. I want to get a new to make sure its reliable.
