Ford Lgt 165 Fuel Filter Or Sediment Bowl?
7 replies to this topic
#1 WesJ OFFLINE
WesJ
  • 2 Thanks
  • 14 posts
Posted July 06, 2014 - 08:46 AM
Hi guys. I have an open-sided 165 with the 341 Kohler. It does not have a fuel pump so it would have to have a sediment bowl right? When I look online all I can find is an inline filter. It didnt have either when I bought it so im trying to find what originally came on it. Thanks guys.
#2 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted July 06, 2014 - 09:02 AM
It should have an inline filter , I have only seen a sediment bowl on older 60's machines .
#3 ChopRod OFFLINE
ChopRod
  • 52 Thanks
  • 72 posts
Posted July 06, 2014 - 09:45 AM
The fuel shut-off has a screen filter that sticks up inside the tank. Have seen some with no inline filter and some that do. Best to use both imo.
  • superaben said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 06, 2014 - 12:23 PM
Even if the original only had one, it is best to put a two filters on an old garden tractor.  Unless you pay to have the gas tank steam cleaned and resealed.
Ben W.
#5 WesJ OFFLINE
WesJ
  • 2 Thanks
  • 14 posts
Posted July 06, 2014 - 12:56 PM
Thanks guys. I seen the screen that fits inside the tank when I took it all apart, I just assumed the filter or bowl was missing. I wasnt sure if it would pull through an inline filter without a fuel pump. My 69 International 125 has a sediment bowl.
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 06, 2014 - 01:06 PM
Should have no problems with fuel starvation unless its clogged with debris.
#7 KennyP ONLINE
  • 40,912 Thanks
  • 47,110 posts
Posted July 06, 2014 - 03:36 PM
The parts list shows only the in tank filter for it. An inline should be fine with it.
#8 WesJ OFFLINE
WesJ
  • 2 Thanks
  • 14 posts
Posted July 06, 2014 - 07:06 PM
Thanks again guys.
