Ford/jacobsen Snowblower Lift Arm Dims
ford lgt. lift arm
3 replies to this topic
#1 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted July 06, 2014 - 08:22 AM
Here are some dims for the lift arm used on Ford/Jacobsen LGT's.
Someone has asked for these so he can fabricate a missing part.
I believe this is the same part as used on the push blade dozer plow.
And is the same for both single and two stage blowers.
Joe
The main tube is a 2" by 3"
The working length is 4' from mounting holes to where the rear cross shaft rests.
  • TomLGT195 said thank you
#2 TomLGT195 OFFLINE
TomLGT195
  • 3,696 Thanks
  • 2,760 posts
Posted July 06, 2014 - 09:56 AM
Joe, the mount at the back and the main tube are the same for the dozer blade. The dozer blade main beam goes straight to the plow.
here's a pic of front where blade attaches
Tom
  • Rock farmer said thank you
#3 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted July 07, 2014 - 08:46 AM
Thank you very much for this post!! i am going to try to get my hands on a plow blade lift arm and modify it is needed.
#4 Tdesmeule OFFLINE
Tdesmeule
  • 3 Thanks
  • 13 posts
Posted October 24, 2014 - 02:26 PM
I have an extra snow thrower lift arm if you're still looking for one
