Ok, Whose Got A Murray/sears
18 replies to this topic
#1 MH81 OFFLINE
  • 29,978 Thanks
Posted July 05, 2014 - 09:48 PM
An acquaintance has a 10/6 "Roper" (Murray) Sears tractor. He would like a three point hitch assembly that would fit it, but I'm having a heck of a time finding a good picture of a Murray rear end with w three point on it.
Here is a very bad picture of the rear end. Can't tell what style three point would go on it. I need to pay as close attention to the handle issue as I can.
Thanks in advance.
#2 whyaretwo OFFLINE
whyaretwo
  • 24 Thanks
  • 34 posts
Posted July 05, 2014 - 10:47 PM
Don't know if these will help you. I can get a picture of the hitch by itself tomorrow. It's not currently on the tractor.
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted July 05, 2014 - 10:50 PM
Those are of a Roper rear end (really nice ride BTW)
The Murray style is slightly different.
  • whyaretwo said thank you
#4 whyaretwo OFFLINE
whyaretwo
  • 24 Thanks
  • 34 posts
Posted July 05, 2014 - 11:06 PM
I misunderstood. I took "Roper" (Murray) to mean they're the same. Looks pretty similar to me, are you sure it won't interchange? I can take some measurements on the mount points if you'd like.
Thanks for the complement! She doesn't get too many opportunities to run the duals. They don't clear the deck well and they just don't make sense when pushing snow. I've been thinking of filling the second pair with RV antifreeze since I usually keep that pair in tire chains for a quick seasonal change over.
#5 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,784 Thanks
  • 5,090 posts
Posted July 05, 2014 - 11:13 PM
http://vintagesearsg...oint_253110.pdf
Page 1, 2, and 3 is the more common Suburban style.
From page 4 on of this pdf file is the hitch you want.
The hitches look identical to me except the handle will have to be shaped different to clear the Murray style fenders.
Edited by Gtractor, July 05, 2014 - 11:19 PM.
  • MH81 and whyaretwo have said thanks
#6 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted July 05, 2014 - 11:29 PM
Any regular 3 point sears hitch should fit fine. You may need the 70's up style lift handle.
#7 MH81 OFFLINE
  • 29,978 Thanks
Posted July 06, 2014 - 05:21 AM
The tractors were supposedly made by Roper, even stipulate the Roper high-low rear end... Near as I can tell, the frame and body is Murray with a Roper built transmission in it
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted July 06, 2014 - 05:33 AM
Thanks guys, that answered my question... I don't think I have an extra one for him.
I might have one that would work, I dont know, bit I do know I don't have that backer bar. i suppose it could be made.
Anyone have measurements on that piece?
#9 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted July 07, 2014 - 08:52 AM
Alan, I've seen the suburban hitches mounted on that rear plate using an adapter plate which move hitch to a more vertical position and I think allows arm to clear fender. Couldn't tell ya where I saw it though, but they can be used.
#10 MH81 OFFLINE
  • 29,978 Thanks
Posted July 07, 2014 - 12:22 PM
I'm going to have to play with it and see.
#11 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted July 08, 2014 - 09:06 AM
I may get more pics today/tonight, guy on MTF just picked up one of these a few days ago with a stock hitch.
Looks like a Burb hitch with just a longer, different bent lift arm.
#12 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted July 08, 2014 - 11:26 AM
I know that long handle would be a bear to ship, but he may sell if interested.
#13 MH81 OFFLINE
  • 29,978 Thanks
Posted July 08, 2014 - 11:31 AM
Let me see what I can do with what I have here. At least I know what I'm gunning for.
Thanks Marty.
  • TAHOE said thank you
#14 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted July 08, 2014 - 08:50 PM
Is my Craftsman II (18HP) a Murray built sears?  Mine has the lift arms coming through the back of the tractor - instead of the outside like the earlier suburbans.
I have several hitches and I think they look the same.  The only difference on the Craftsman II are spacers behind the top of the lift plate to create clearance for the fender pan for the lift arm.
I have 2 different lengths of the lift arms.  I'm guessing the they are based on the attachments.
#15 MH81 OFFLINE
  • 29,978 Thanks
Posted July 08, 2014 - 08:55 PM
The 15" arms are for the tillers and the 18" are for almost everything else.
As for the lift piece, do you have a pic or two of that setup?
This is a combination trying to help a guy out and doing a little horse trading. It doesn't need to be perfect, but it does need to be useable.
  • motobreeder said thank you
