What Model Briggs Is This?
7 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted July 05, 2014 - 07:53 PM
I know this engine was built in the first half of the 1950s and is 3 hp. It looks like a Briggs.  If a fellow wanted one, what would he be looking for?
  • hamman, trowel, Traill95 and 2 others have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 05, 2014 - 08:13 PM
Briggs model 9.
  • rustyoldjunk and New.Canadian.DB.Owner have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted July 05, 2014 - 08:35 PM
Okay, anyone got one they will part with?
#4 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 9,864 Thanks
  • 5,950 posts
Posted July 21, 2014 - 01:50 PM
I've been looking for one of these for a few years. They are out there but usually people want your arm for them
  • trowel and New.Canadian.DB.Owner have said thanks
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 21, 2014 - 05:14 PM
the 9 isn't really that easy to find, seems like most tractors went from a model 8 briggs, of 2 to 2 1/2 hp, some even 2 3/4 right on to the model 14, which was a 5hp. Most of the time if you see a 9, its on a simp tractor. Wards went with wissy engines to get their bigger hp.
I find this whole hp of engines thing very odd. Some have even numbers like 1 1/2,2 3,5 etc, others rated theirs at goofy things like 1.8 or 6.3. The even odder ones are the rated hp at 3000, 3200, or 3600 rpm's, all in the same basic engine.
#6 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted July 21, 2014 - 09:05 PM
I have found two that look like the model 9: one is 8hp and the other 5hp.  Is there any cosmetic difference between the 3hp and the 5 or 8hp versions?  Are the larger hp engines bigger or just bored larger?  If I stick a 5hp version on a tractor will (smart) people notice without reading the tag?
  • Lauber1 said thank you
#7 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 21, 2014 - 10:07 PM
Well its both, each engine is larger than the next, inside and outside. There are several in this group, 9,14, 19, 23, so you get 3,5,7.25 and 8.25 hp. Some times the number hp is fudged a little on the top end two. A 19 is basically a bored out model 14. There is a huge physical size difference in the 19 and 23, and a 9 is pocket sized compared to the 23. if you cant find a 9, then I would just put the 14 on it and let it go for now. one will turn up as soon as your done looking.
#8 jtrojek OFFLINE
jtrojek
  • 1,132 Thanks
  • 580 posts
Posted July 22, 2014 - 03:24 PM
There's one on eBay right now, but it has a gear reduction.
http://www.ebay.com/...=item1e8d85423c
  • Lauber1, trowel and New.Canadian.DB.Owner have said thanks
