Briggs 9Hp Model 23 (Copar Panzer) Bad Coil?
13 replies to this topic
#1 engineguy63 OFFLINE
engineguy63
  • 81 Thanks
  • 59 posts
Posted July 05, 2014 - 07:42 PM
OK Guys, I am perplexed. Engine was running for a short time, then sputtered and died. I could not see a spark so I changed points (new), and a known good capacitor. I have what seams to be a good spark (when turning over with spark plug laying on cylinder head). Engine will not fire even though I sprayed starter fluid in carb several times and into cylinder directly. After repeatedly pulling engine over I pulled the plug, yup still getting spark. Can a coil go bad and spark outside of cylinder but not under compression? Also butterfly was setup with a spring to the lever as shown, this does not seam right as tesion keeps the butterfly closed even if I move the throttle ?????? Thanks for the help!
#2 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted July 05, 2014 - 07:46 PM
Sometimes a weak spark will show when the plug is out (Not under compression) and when the plug is in you get no spark or weak spark.
Put  on an ignition tester and see what happens, If you dont have one they are faily cheap and I can get them if need be.
  • trowel, New.Canadian.DB.Owner and engineguy63 have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 05, 2014 - 07:48 PM
Yes, it will, 9, 14, 19 and 23 all do that, if the plug is coming out wet with red/orange hue spark then the coil is on it's way out, change it.
  • New.Canadian.DB.Owner, superaben and engineguy63 have said thanks
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted July 05, 2014 - 07:56 PM
Could also be flooded.  Awesome spark won't help you if the fuel to air ratio is to high.  Let it sit overnight with the plug out, or try one of the "hold my beer & pass me some fire" cures.
  • trowel and engineguy63 have said thanks
#5 engineguy63 OFFLINE
engineguy63
  • 81 Thanks
  • 59 posts
Posted July 05, 2014 - 08:13 PM
I should have mentioned, Spark is blue and you can hear it (nice crack)...........will let it sit overnight and try again, but did not even Cough when I turned it over.........totally just dead.  you would think after spayying starter fluid in it you would get something!
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 05, 2014 - 08:15 PM
Hum, im thinking Brian and Mark is right, try again tommorow by dumping a little gas into the spark plug hole and crank it.
  • New.Canadian.DB.Owner and engineguy63 have said thanks
#7 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 05, 2014 - 09:06 PM
Here's another one that got me for awhile.  I had a great spark with a plug laying on the cylinder head.  It would jump the max I could throw at it.  But inside the cylinder it was dead as a doornail.  I could dump gas right in it, and I even used starter fluid, something I do very rarely.  I only keep the stuff to kill wasps.
I finally figured out was causing the problem.  The spark plug wire was broken internally and while it was not connected enough to gain any fire worth enough to write home on the cylinder head, it must have connected while the plug was lying on the engine head.
May not be what's happening to you, but it might be worth checking.
Ben W.
#8 engineguy63 OFFLINE
engineguy63
  • 81 Thanks
  • 59 posts
Posted July 06, 2014 - 06:13 AM
Ben, I think that might be it, was thinking that very thing today. I am gonna hook up an automotive 6 volt coil to the points and see if it wants to go....if it does than I don't need to worry about the carb.
  • trowel said thank you
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 06, 2014 - 06:19 AM
Engineguy63, were in Ma are you located, i am in Ashfield.
#10 engineguy63 OFFLINE
engineguy63
  • 81 Thanks
  • 59 posts
Posted July 06, 2014 - 06:24 PM
Small world, My Brother lives in Ashfield, I am in Easthampton
#11 karel OFFLINE
karel
  • 2,072 Thanks
  • 1,384 posts
Posted July 07, 2014 - 04:17 AM
  • engineguy63 said thank you
#12 engineguy63 OFFLINE
engineguy63
  • 81 Thanks
  • 59 posts
Posted July 07, 2014 - 06:37 PM
Hi Karl, I hope not, but may need a 9 hp briggs tank....my friend thinks he might have one, but not sure. Do you go to ZAGRAY?
  • karel said thank you
#13 karel OFFLINE
karel
  • 2,072 Thanks
  • 1,384 posts
Posted July 10, 2014 - 06:03 AM
yes I will be there
#14 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 10, 2014 - 05:54 PM
Cool, we may have crossed paths.
