Found An Ht20D...now Have To Fix A Hydraulic Leak
ht20d hydraulic leak bolens diesel
10 replies to this topic
#1 whitefishblues OFFLINE
whitefishblues
  • 50 Thanks
  • 43 posts
Posted July 05, 2014 - 03:59 AM
So there I was, searching Craigslist for Bolens large frames again...all prepared to hit the red X in case my wife walked by.  I scrolled down and this fuzzy picture showed up of what looked like maybe a large frame hood, but with silver flames painted on it.  I passed it by.  A few days later it was still there.  I clicked.  The ad said that the seller didn't know much about it, but that he found a model number on it...2289.  I Googled, and when I saw "HT20D", well, I figured I was soon to turn some cash into another Bolens large frame!
It seems to be in really good shape.  No battery yet, but the seller did fire it up using his truck battery.  The fuel tank is odd - just a little bottle shaped thing on the side with lines attached at the top and bottom.  The seller said his friend modified the tractor for his daughter to use in tractor pulls, so he thought the fuel tank setup had something to do with that.  I'll return that to stock.
I was hoping this one wouldn't turn into another project...because I certainly have enough of those.  But...one of the front hydraulic lines has a hole in it.  The vibration of the engine has caused a bolt on the engine support frame to wear through the hydro line.  It looks to me like I'm going to have to pull the engine and the dash/steering support to get at that line to replace it.  I have a replacement line from an HT20 parts tractor.
I can't quite figure out how to do this.  I don't see any obvious places to hook onto the engine to hoist it out of there.  I thought of jacking it up from underneath but it has cooling fins under there.  They look pretty sturdy, but I sure don't want to damage the engine.  Anyone have any advice?  I'm stumped, and I'm a little nervous with this one...I know there aren't a lot of these around and that engine parts are probably not available.  The engine runs great so I want to make sure I don't screw it up.  Any advice is much appreciated!
Thanks!
  • OldBuzzard, blackjackjakexxix and Newpaws493 have said thanks
#2 Newpaws493 OFFLINE
Newpaws493
  • 1379 Thanks
  • 1813 posts
Posted July 05, 2014 - 06:01 AM
I was hoping this one wouldn't turn into another project...because I certainly have enough of those...
:bigrofl:  :bigrofl:  Really?... On the serious side , I hope you can resolve the identified issues without them being too much of a PITA.
The guys who know these better'll be along to help ya through. Looks like a solid machine otherwise :thumbs: GoodLuck!
  • whitefishblues said thank you
#3 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted July 05, 2014 - 06:43 AM
Congrats on the great find! It does look to be in good condition. Good rubber too!
#4 KennyP ONLINE
  • 50045 Thanks
  • 52262 posts
Posted July 05, 2014 - 06:57 AM
Got pics of the engine? May have to make some tabs to hook small chain to lift it.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4256 Thanks
  • 5840 posts
Posted July 05, 2014 - 07:25 AM
Be a man. Wrap your arms around it!
#6 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted July 05, 2014 - 07:31 AM
Poor tractor, it has had a rough life.
Hey.  Save that for your wife.
Ben W.
  • crittersf1 and whitefishblues have said thanks
#7 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted July 05, 2014 - 11:21 AM
i think you should leave the paint job the PO put some time into that and i think it looks good not stock but good.
#8 whitefishblues OFFLINE
whitefishblues
  • 50 Thanks
  • 43 posts
Posted July 05, 2014 - 01:00 PM
I haven't decided yet on the flames.  It's a very nice, apparently professional paint job.  I like the look of the stock Bolens but probably not enough to go to the trouble of changing it back.  I think I'm secure enough to use it as is.   :love:
Here are pictures of the engine.
#9 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 05, 2014 - 01:53 PM
That rascal looks to be in very good shape :thumbs:
Here's a pic of my 20D's engine showing how the original air cleaner and fuel tank are mounted.
For any parts other than the engine, you can use HT23 parts.
Edited by OldBuzzard, July 05, 2014 - 01:54 PM.
  • Newpaws493 and whitefishblues have said thanks
#10 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted July 05, 2014 - 05:36 PM
To lift one of those engines out of the frame on my HT20D, I made lifting tabs that I could attach after removing the aluminum shrouds around the top of the engine.
Looking at the pics of your find, I wonder if the fuel pump and/or the fuel shut-off solenoid are still functional. The stock routing for fuel goes from the bottom of the tank to the fuel pump/filter/solenoid, then to the injectors and excess back to the fuel tank. Yours looks like the PO made a pressurized system with that small tank. The fuel tank for the HT20D's is specific for that model, although you could modify a stock HT23 tank to mimic the proper one.
I am guessing that you already know that the exhaust on that is not stock, but it is nicely done, and would work fine with a rain cap.
  • Bolens 1000, Newpaws493 and whitefishblues have said thanks
#11 whitefishblues OFFLINE
whitefishblues
  • 50 Thanks
  • 43 posts
Posted July 05, 2014 - 06:18 PM
OldBuzzard...thanks for the picture.  I thought it looked like the air cleaner would be in the way of a normal fuel tank.
LPBolens...did you just bolt the lift tabs on?  I'll take the shrouds off to see if it's obvious.  You might be right about the fuel pump and shutoff solenoid.  Can I test those somehow?
I have the wiring disconnected, the dash off (it's the plastic version and is cracked, so I'm replacing it with a metal version), and almost have the steering column/dash support off.  The pin that holds the brake pedal on is being pretty stubborn, and I can't get the last bolt off without removing the brake pedal (because the brake lock is in the way).
So far the only damage I caused is I broke the oil pressure switch.  Part #1739840.  Anyone have any ideas for a replacement?
Also tagged with one or more of these keywords: ht20d, hydraulic, leak, bolens, diesel
