Kohler Ch20 In A 916H, Anyone Here Done This Yet?
26 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 04, 2014 - 01:02 PM
Well, my K341S blew a hole in the block and getting another one around here is like finding chicken teeth :wallbanging:
So, I have scrapped my pennies together and picked up a Kohler CH20 OHV motor to try and power this thing.
Has anyone here done this before?? If so, any helpful hints?
  • propane1 said thank you
#2 propane1 ONLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted July 04, 2014 - 03:12 PM
I have not done any engine repowering yet, so I am interested also, as I am having K321 engine troubles.  Noel
#3 JDBrian OFFLINE
  • 9,636 Thanks
  • 14,156 posts
Posted July 04, 2014 - 03:18 PM
One issue is always crank height. If you have a u jointed drive shaft it isn't as much of an issue. Could you take some pictures and post some info about the re power? It's becoming more common to re power the older GTs as the engines are wearing out after 30+ years of use.
#4 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted July 04, 2014 - 03:22 PM
We took out a Kohler k 241 10hp and easily replaced it with a CH 18 vtwin (same size as a 20) and only had to re- wire the ignition to shut it off and drill 2 new motor mount holes !! It was retardedly easy and the V twin is super smooth and crazy powerful!!! And all this under the bonnet of a Ford LGT 100 .
#5 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 04, 2014 - 04:01 PM
This is the motor that I am working with
Looks l ike I have to raise the motor up about 1/2" or so to line up the driveshaft.
Edited by victor3ranger, July 04, 2014 - 04:02 PM.
#6 Talntedmrgreen OFFLINE
  • 3,279 Thanks
  • 2,311 posts
Posted July 04, 2014 - 04:15 PM
The Command is a popular repower for 900/7100 series tractors. The CH18 became standard power for many late model Sovereigns. If you do a search on it over at simpletractors you find find several tutorials.
#7 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 04, 2014 - 09:39 PM
Thanks Josh I will do that.
#8 TomLGT195 OFFLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted July 05, 2014 - 06:18 AM
Keith , open or closed sides?
#9 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted July 05, 2014 - 08:31 AM
Closed sided machine , Tom. And I'msure it could be done to the open sided units with bolted in engines (late model open-sided units)and a fuel tank relocation.
  • TomLGT195 and propane1 have said thanks
#10 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 05, 2014 - 01:27 PM
Did you do this on a 916??
On mine the crank looks to be maybe a half inch lower than the drive shaft and the holes where the motor mount bolts go thru are much larger than the one for the K341 that came out.
What did you do to attach the crank to the drive shaft??
As for the rewire, what did you have to do with that part?? I really don't want to fry any of the electrical stuff.
#11 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted July 06, 2014 - 09:09 AM
 for the driveshaft I used the same adapter that was on the K series , bolted right on . As for the motor mounts, they are different on the Fords. They are 2 separate plates mounted on rubber. For your app. I would get the engine lined up by shimming it and re drill the 4 holes. Then for ignition I used a relay. wired so the ignition power opened the contacts that would ground the ignition cut off wire to ground to shut off the ignition. Worked perfectly.
  • TomLGT195 said thank you
#12 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 06, 2014 - 02:27 PM
skyryder2, when I get to the rewire part of this I will be picking your brain, wiring and me don't seem to follow each other very well :D
#13 skifoof OFFLINE
skifoof
  • 54 Thanks
  • 86 posts
Posted July 06, 2014 - 06:43 PM
I bought a 919 that has this engine in it on mine it has a oil filter on left side and they had to notch the frame for this...and currently has carb flooding issues
#14 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 07, 2014 - 02:28 PM
I have already made the notch in the frame for the oil filter. :D
#15 TomLGT195 OFFLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted July 07, 2014 - 07:15 PM
Hey, where's the pics?
