Need 3Pt Hitch Parts- Any
6 replies to this topic
#1 glgrumpy ONLINE
  • 8,365 Thanks
  • 7,753 posts
Posted July 04, 2014 - 11:47 AM
Buying a late model Plastic King. Wish to find the 3pt for it. Has to be from Plastic King, 85 and newer to work, old ones don't work.  Might consider the lower lift arms and the lift links from older unit, they will work. Upper lift arms and lift link totally diff. Interested in any of the parts, complete or not.
#2 TAHOE OFFLINE
TAHOE
  • 7,740 Thanks
  • 5,580 posts
Posted July 27, 2014 - 11:02 AM
Grumpy, this guys has listed 3 pt for later underside lift PK, not sure if that's what you are looking for.
http://www.mytractor...ad.php?t=641577
#3 glgrumpy ONLINE
  • 8,365 Thanks
  • 7,753 posts
Posted July 27, 2014 - 07:20 PM
I think that is just for metal body style. Later ones had under body cylinder to lift.  I found in attic most of the hitch which I thought I had sold, but missing the main lift arms and the big 1" lift arm. I now have  a pair of lower arms off the metal ones that I am re-bending dog-leg style like the late ones, and have a drawing of the Lift link to make from 1" round stock, real simple, so am good to go after-all. I should be good unless the correct arms and lift link pop-up seperate, I might have interest in those.
#4 TAHOE OFFLINE
TAHOE
  • 7,740 Thanks
  • 5,580 posts
Posted July 27, 2014 - 07:23 PM
I can take pics of mine if ya need them since mine is late style and complete.
#5 glgrumpy ONLINE
  • 8,365 Thanks
  • 7,753 posts
Posted July 28, 2014 - 07:51 AM
No need. You have Plastic Body one?...OH, was that you had Snapper? NO, that didn't have hitch I think. Even the smaller 1218's and such have diff style, similar, but diff. I have plenty of pictures and am familiar with the units, thanks!
#6 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted July 28, 2014 - 10:33 AM
This?
#7 glgrumpy ONLINE
  • 8,365 Thanks
  • 7,753 posts
Posted July 28, 2014 - 01:58 PM
User, NO, nothing like that at all. Plastic Kings use big 1" rod with angle bend and just holes in ends. We've been talking on that if you recall. Chuck measured one of his and I'm making up those lower arms from you to fit. Blasted and have the balls worked loose now, just gotta try to press straight first, then dog leg. I DO need the dog leg dimensions, but Chuck should be able to help on that again I hope.
