1965 110 Pto Info
7 replies to this topic
#1 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted July 01, 2014 - 09:17 PM
I'm replacing the drive belt for the foot engaged pto on my 65 model 110. I can't find it anywhere in the online parts catalog on the jdparts site. (Pc 855 I believe for model 110 prior to sn100000.) I have been able to locate the part number of m40222 for the belt (but not in the catalog). I would like to see the parts breakdown for the foot engaged pto because it looks like one part on mine has been rigged and I want to fix it correctly. Am I missing something? Any ideas?
#2 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted July 01, 2014 - 10:40 PM
 Lets see If I do this correct
  • johndeereelfman, sacsr and rbooker have said thanks
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 01, 2014 - 10:58 PM
http://gardentractor...lts#entry464529
i went through the same thing if the answers aernt in that thread im pretty sure jdelfman will help you out
  • Littledeere, johndeereelfman, sacsr and 1 other said thanks
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted July 02, 2014 - 03:33 PM
Kenny,
Do you have a blow up for the actual pto engagement detail for him? I don't have it scanned or I'd post it.
rbooker,
You will more than likely have to look under the 38 mower deck parts break down, or the 30 rototiller parts break down, as this pto was an added option kit for both of these attachments.  You won't find it listed with the tractor parts. Hopefully we'll have what you need shortly.
Edited by johndeereelfman, July 02, 2014 - 03:37 PM.
  • Littledeere and rbooker have said thanks
#5 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,550 posts
Posted July 02, 2014 - 04:52 PM
Here is the diagram Troy is referencing and I did find it on JDParts under the "38" deck info as the "throw out assembly."
Edited by Trav1s, July 02, 2014 - 04:53 PM.
  • olcowhand, Littledeere, johndeereelfman and 1 other said thanks
#6 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted July 02, 2014 - 06:24 PM
Thanks for the help Travis. That should be exactly what he's looking for.
  • Littledeere, Trav1s and rbooker have said thanks
#7 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted July 02, 2014 - 09:53 PM
that is exactly what i was looking for.  throw out assembly.  turns out im only missing a bushing.  deere has quite a way of making it difficult at times to find things on the parts front.  another example: the individual row units on a 1720 planter are not included in the parts catalog for the planter.  you have to look under attachments.  i did look at attachments in the 110 parts catalog but the mowers listed there did not include the 38 inch deck for some reason or the "throw out assembly".  go figure.  the names for some of the parts get me at times as well.  dont always make a lot of sense.  all that aside it is very nice to be able to search the parts catalogs for all my equipment and get specific part names and numbers and breakdowns on assembly.  especially if you have to undo some previous "engineering".  many thanks guys!
#8 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,550 posts
Posted July 03, 2014 - 10:58 AM
Fair warning - the bearing went out on the tensioner pulley and the replacement from Deere required me to use a spacer.
  • johndeereelfman and rbooker have said thanks
