Upgrading Bolens (Customizing)
4 replies to this topic
#1 stetson OFFLINE
stetson
  • 46 Thanks
  • 49 posts
Posted July 01, 2014 - 10:10 AM
Has anyone ever run a bypass line from a 12d to run a filter or a oil cooler on tractor? Has anyone ever run a cooler on the hydrostatic trannys? Im, knew to these makes and models so I don't know if it's possible but if it is I'd like to do it cooler is better
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 01, 2014 - 10:23 AM
I'm not sure about adding an oil filter to the engine.
Bolens did offer a hydro cooling kit for the HT series Large Frames, and it was standard on the 2389S model HT23.
I'm guessing that it wouldn't be too hard of a job to put a hydro cooler on a 1250.
#3 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted July 01, 2014 - 11:20 AM
I don't think that type of engine is pressurized to allow an oil filter you may need a pump.
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 01, 2014 - 11:42 AM
These engines have been running stock for over 50 years, why change something thats working?.........
#5 stetson OFFLINE
stetson
  • 46 Thanks
  • 49 posts
Posted July 01, 2014 - 05:04 PM
Well the engines are oil slinger style engines so no there's not any pressure an external pump would be required and to Answer as to why I don't know why I thought of it I just did..... running cooler is never a bad thing
