Snow plow deflector
6 replies to this topic
#1 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted January 30, 2011 - 09:21 PM
I was thinking a deflector would help plowing , has anyone added them to there plows and if it was worth adding .Here's a picture of the tractor I want to put it on and a Meyer's one ,
Meyer Products: Utility Vehicle Plow0107111649.jpg
#2 MH81 OFFLINE
Posted January 30, 2011 - 09:27 PM
I made some rubber ones out of some HD mud flaps. Put some srings behind to help with rigidity & it made a big difference. Until I ripped one off that is. When I do it over, I'm making steel ones. It's a big help with the fluffy stuff. It stops rolling off the side.
Edited by MH81, January 31, 2011 - 11:18 AM.
#3 mjodrey OFFLINE
Posted January 31, 2011 - 05:41 AM
I did the same thing on my old 420 JD dozer a few years ago,but it also ripped.
#4 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted January 31, 2011 - 09:24 AM
Mud flap might make a quick ( cheap ) fix . I only need it for the RH side of the blade . I searched " snowplow wings" but that might not help the problem I'm having with the snow going over top .
#5 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted January 31, 2011 - 09:36 AM
If it's over the top of the blade then a quick solution would be to bolt a piece of 3/4" plywood along the full length of the top edge of the blade.Make it what ever width you'd like to heighten your blade.I'am sure a half dozen bolts spaced evenly along the top edge would suffice.Use about a 4" overlap on the blade and you'll be good to go.Larry
#6 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted January 31, 2011 - 11:35 AM
Larry . I like the plywood idea, I could try a piece and it would be easy to fine tune the shape and if it works good maybe copy the shape in steel . Thanks
#7 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted January 31, 2011 - 09:31 PM
Made this up tonight out of an section of mud flap ,cut a piece of oak on a taper with a slight curve at the end , will see if this works .DSC07652.jpg
