Got A Battery Backup
11 replies to this topic
#1 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted June 30, 2014 - 10:23 AM
Been slow getting this, but finally got a battery backup system for my computer & my TV box so when the electric blinks, everything keeps right on it's merry way.  I figure the short glitches in the grid is part of my computer problems over time.  Now things should go smoother.
It's an APC 800
  • Texas Deere and Horse, KennyP, Newpaws493 and 1 other said thanks
#2 Alc ONLINE
  • 6,910 Thanks
  • 7,472 posts
Posted June 30, 2014 - 10:36 AM
Is that like a storage battery inverter kind of thing ?
#3 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted June 30, 2014 - 10:39 AM
Exactly.  Has 6 backup power AC plugs on the back, and 3 more surge protected only AC outlets.
#4 HowardsMF155 ONLINE
  • 2,863 Thanks
  • 2,988 posts
Posted June 30, 2014 - 12:01 PM
That is most certainly a needed accessory for any type of desktop computer.  Windows doesn't like to be interrupted without notification!
  • KennyP and HDWildBill have said thanks
#5 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted June 30, 2014 - 01:01 PM
Just got everything hooked to the backup system and ran a self-test....all is great!  Battery run time is estimated at 36 minutes running the PC, monitor, TV box, and modems.  The software safely shuts down my computer if battery gets so low, or I can set it to shut down after X minutes on battery power.  If computer is shut down, then the TV box & other items stay under battery power till she's drained.
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 30, 2014 - 03:36 PM
Worth it's cost in saved grief and time trying to recover from power glitches or outages. Every instrument in our lab, big or small, has one of those on it. The building has a 500kw diesel backup but it takes 10seconds or so to come on. That one is a generous size for your setup which is why you have got a nice long 36 minutes backup time. Batteries should last 4- 5 years on average.
  • olcowhand, KennyP, HDWildBill and 1 other said thanks
#7 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted June 30, 2014 - 04:02 PM
How much was that bad boy?  My swap to SSD drives has reduced the problems but power outages still hurt hardware.
#8 MH81 OFFLINE
Posted June 30, 2014 - 05:16 PM
Nice not to worry about the little bumps in the grid.
Just stay under the listed 540 wattage rating with your stuff. The batteries will cook if you are over. We had some 300w units at work running about 375w worth of stuff due to the person hooking them up thinking the VA rating = Watts... It doesn't, they lasted just over a year. Batteries all swollen and the juices cooked out of them.
  • HDWildBill and TomLGT195 have said thanks
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 30, 2014 - 06:30 PM
You will definitely love having the ups on your grid.  As you said it smooths out the grid with the hiccups but also with brown outs which are worse on the hardware the loosing power.  I can't imagine not having mine on the grid.
#10 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted June 30, 2014 - 08:11 PM
Just $64.99 DELIVERED!  Now these were a special build, so the phone & data ports don't offer protection, but that's ok with me for this price.  HERE's a link.
#11 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted June 30, 2014 - 08:16 PM
This one has alarms that go off if you overload it.  I'm only using 113 watts of the available 540, so I'm good.
#12 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted July 01, 2014 - 07:30 AM
That is a great deal!  Might have to put my cable modem and router on that.
