Update On The B12
3 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted June 29, 2014 - 04:41 PM
Well, what do you know?  Here it is the end of June and I actually got to work on the B12 for the third time.  I'm going to set a record this year.  I got the valves all set (I think) and re-installed.  Once I learned about the valve spring keepers, it was a piece of cake.  So I got eveything back together, put oil in it and put juice to it.  It was putting pretty good.  Sounded a lot different than when I tried last.  It turned over pretty well but never did fire and all my gas started to run out onto the floor.  I want to get this thing to fire on gas before I do much else to it.  We're getting there.  Couple more years and it may just start!
  • Bill56, MH81, sacsr and 4 others have said thanks
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted June 29, 2014 - 04:54 PM
Don't loose faith Jeff. Glad you got it back together.
Oh, and that gas straining feature, I have a couple that do that too. I would tell you how I "fix" it, but I don't want the grief :D
  • Bill56, tinbender7 and David Brown have said thanks
#3 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted June 29, 2014 - 05:28 PM
Hope you can find some more time to work on it. As an owner of more non-running, than running tractors, I can relate to your post.   :D
  • sacsr, tinbender7 and David Brown have said thanks
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted June 29, 2014 - 06:46 PM
Thing is, I want this thing running because if I would happen to get the implements, I want to be able to plow with it.  I guess I could use them on the B10 also but I want to use this B12 with the hi/lo tranny.
  • Bill56 and MH81 have said thanks
