Wrench For Hydraulic Cylinder
6 replies to this topic
#1 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted June 29, 2014 - 01:31 PM
Hi Everyone,
What kind of Hydraulic Wrench does my Hydraulic Cylinder use? I have seen other cylinders with holes to attach a special wrench to, but this one just has a slot cut in one side.
Thanks!
  • Texas Deere and Horse and New.Canadian.DB.Owner have said thanks
  • 14,814 Thanks
  • 15,501 posts
Posted June 29, 2014 - 01:45 PM
Are you sure the end is threaded? It might be a internal retaining ring. Also make sure the end isn't held in place by the hose fitting that screws in that end of cylinder. More photos would help.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 29, 2014 - 02:26 PM
Never seen one like that before. Is it off a tractor or a factory loader attachment? If it's a custom built job then who knows where the cylinder came from.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 29, 2014 - 02:47 PM
Ditto!  You can see the slot & circlip if you blow the photo up enough.
  • HDWildBill and FilledTires have said thanks
#5 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted June 29, 2014 - 04:20 PM
I see the slot and clip now. how do I go about removing it? I don't need to do it now, but I am planning ahead and learning as much as I can before I need to rebuild the cylinder int he future.
Thanks!
This came off a Factory Kwik Way Front End Loader from the 70's
#6 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted June 30, 2014 - 12:31 PM
You need to drive the end of the cylinder back into the cylinder enough to remove the ring, then you can use the piston to help as a slide hammer to drive the end cap back out of the cylinder.
  • Alc, New.Canadian.DB.Owner and FilledTires have said thanks
#7 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted June 30, 2014 - 09:33 PM
So the part I need to drive back is the part in the photo that surrounds the Hydraulic Ram, correct?. Can I just use a big punch and hit it back?
