* * * * * 2 votes
MF/snapper 1855 will one day be my MF2655 custom
65 replies to this topic
#1 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 28, 2010 - 10:51 PM
I bought a snapper 1855 minus the engine about a year ago. Soon after that I found a Kohler Aegis 26 on ebay for cheap. I started thinking how cool it would be to put a water cooled modern twin in the old 1855. So, I bought the Aegis after I figured out that it would just barely fit under the hood.
Here is the 1855 as I first found her... the engine was already sold to another buyer.:wallbanging:
Edited by tweidman, November 07, 2010 - 09:34 AM.
  • jpswift1 said thank you
#2 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 28, 2010 - 10:56 PM
When I got her home I started assembling the pile of parts to see what all was missing. I knew that several of the plastic parts were gone. The seller promised me the tank, but never came through.
#3 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 28, 2010 - 10:59 PM
I set the engine and radiator in place to see how things would fit....
Tight but not too bad.
Edited by tweidman, November 07, 2010 - 09:35 AM.
#4 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 28, 2010 - 11:03 PM
One of the first things I wanted to get worked out was the radiator mount. It was originally mounted to the engine, facing the wrong way.
It fits under the hood, that's a good start, time to drill some holes and bolt her down.
  • ducky said thank you
#5 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 01, 2010 - 05:32 PM
I did not notice when I bought the tractor (and the seller did not point it out either) the tab on the rear end that supports the 3 point was broken off. I found the part that broke off in a box of parts that came with the tractor. I was taking a welding class at the time. I brought the tractor to class and learned how to weld cast iron.
Then a couple of days later I saw an axle on ebay for really cheap. So, I bought it, even if my weld holds fine, the replacement will look better.
#6 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 01, 2010 - 05:47 PM
I did not have the upper or lower dash. They are plastic and hard to find in okay condition. I gave up the search for finding one that wasn't broken. Olcowhand (Daniel) had one that was not in great shape, but would serve as a model.
I bought a sheet of 16g steel and headed off to welding class again. Not so much to use the welders, but to use the break and sheer and other equipment.
After about 3 hours of playing with the toys in the shop, I came up with this.....
I did not get a chance to grind the welds down while I was in class. I probably did not even need to weld the outside edge. You know the saying...if it's worth doing, it's worth over doing.:D
After some time with the grinder at my home shop, I ended up with this...
Edited by tweidman, November 08, 2010 - 09:30 PM.
#7 olcowhand ONLINE
  • 41,280 Thanks
  • 31,452 posts
Posted March 01, 2010 - 08:46 PM
:thumbs:I'll sure be glad to see the final product of this great project! Love what you've done so far!
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted March 01, 2010 - 09:56 PM
If this one turns out like your MF12 it's going to be nice, water cooled engine put a good muffler on that and it will be quiet.
#9 massey driver ONLINE
massey driver
  • 1,429 Thanks
  • 1,577 posts
Posted March 01, 2010 - 10:09 PM
Wow looks like lots of work going to be put into this one.You'll have a nice machine once its done.Will be nice to see the end result.I really like the idea of the water cooled motor. Larry.
#10 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted March 01, 2010 - 10:28 PM
What kind of welder are you using. I'm thinking of buying a little gasless flux core mig welder, for doing stuff like this, I know the gas mig welder would be nicer, but for one thing I wont be welding any 1/4 inch or larger steel, but rather smaler things like this
#11 olcowhand OFFLINE
  • 41,280 Thanks
  • 31,452 posts
Posted March 02, 2010 - 09:56 AM
Mike, I built my entire FEL using my Clarke EN180 (180 amp)gas/no gas. I use flux wire to keep costs down. Cost me around $500 delivered and is a very good welder. I didn't catch what Todd gave for his, but it's a SUPER welder for sure! I could have used my 250 amp Hobart stick/TIG welder, but I wanted to see what the Clarke could do...and do it can!
#12 mjodrey ONLINE
  • 2,356 Thanks
Posted March 02, 2010 - 11:21 AM
It really is looking good so far.Good job. :thumbs::thumbs:
#13 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 02, 2010 - 01:21 PM
To do the welding pictured, I was using a super huge Lincoln mig at the welding class. It worked great, but I don't even want to guess what it cost.
At home I have been using/borrowing a small 110v lincoln with gas. It works good, but multi pass welds are needed for heavier stuff.
I just purchased a used Millermatic 35 220v welder with gas. I have not used it yet. I am hoping this welder will do anything I will ever need, and got a great deal on this used machine $385 w/ a size K tank.
I'll post some more progress pics and text soon and get this post up to date with where I am now. I actually worked on it for the first time in months this past weekend.
Edited by tweidman, November 08, 2010 - 09:31 PM.
#14 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 02, 2010 - 06:05 PM
I did get the rad support bolted down, and it fit perfectly.
About a half of an inch on both sides of the hood.
Edited by tweidman, November 07, 2010 - 09:36 AM.
#15 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 02, 2010 - 06:09 PM
I also got the lower dash built and welded up in welding class. It was much easier, no curves.
It still needs some grinding.
