Bolens 1886
44 replies to this topic
#16 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted July 08, 2014 - 08:24 PM
So i did a little work today and restored some glory to the old girl today. So i removed the home made trailer hitch from the back and checked the trans fluid and it was milky and it had this home made dip stick.
So i found this nos babby on epay.
So i proceeded with the fluid and filter change and ran into a stripped drain plug so now i need to locate one.
Not 1886 related but i bought a set of chute rods and the gear for my large frame snow caster and they arrived with the gear assembly broken so i fixed that today
Edited by JohnWR, July 08, 2014 - 08:36 PM.
#17 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 20, 2014 - 05:59 PM
So finally got some work done to the 1886. I finally replaced the wobbling drive shaft and fan. I am not really happy the back work wobbles a tab bit so i think next i may pull it back out and add a set screw to it.
After i finished the drive shaft for today i really installed the 3 Point hitch and test fit everything.
I also got my power angle blade back up and moving. I do have a question about the lift arms are they the same length as ones for the 1250-1477 for the 1886 or should they be longer. with my arms adjusted as long as they can go the plow only lifts a few inches but lifts the whole tractor up.
Here's a pick of the old drive shaft
#18 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted September 20, 2014 - 10:17 PM
Thats a old factory replacement slip shaft.
The lift arms for the blade are longer for the 1886.
#19 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 20, 2014 - 10:45 PM
It's ashame that the engine yoke is wallowed due to the key way being gone and the shaft being allowed to move just a bit. I will keep that shaft and maybe at a later date find a new engine side yoke and have the trans side turned on a lathe to fit the fan.
Is there any chance you have the length for each set of rods just for reference.
#20 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted September 20, 2014 - 10:49 PM
I think I do I'll look tomorrow.
#21 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 21, 2014 - 05:10 PM
Well i went and got my ebay deal of the year item 12" cat 0 brinly plow. at 1.00 i don't think i made out bad i felt kinda bad he only accepted paypal so i tipped him a 20.
DSC_0274.JPG DSC_0275.JPG DSC_0276.JPG DSC_0277.JPG DSC_0278.JPG DSC_0279.JPG DSC_0280.JPG
Edited by JohnWR, September 21, 2014 - 05:10 PM.
  • sacsr, NJKen and Sawdust have said thanks
#22 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted September 22, 2014 - 10:33 AM
John... Glad to hear your'e  enjoying your'e new Bolens...
It has been an interesting thread..   I have the 1477,,, it's little brother,,  but their very simular..  I enjoyed the part with the Ballard  Hitch..  I'm trying to make my own,,, But I think I should have just bought one from them,,and be done with it..
  As for the milky hydro fluid,,,  I changed mine a few years back and put Dextron in it..It turned milky pink..  I drained it again and used Ford type F... NO more milky pink froth..
I wish I had the duel hydralics ... Wonder how hard that would be to change it.????
I may PM you on the balard stuff..       Anyway,,, Enjoy it................................              sodi..
#23 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 22, 2014 - 05:33 PM
Wes over a Ballard was a pleasure to deal with he builds these to order i just happen to get one pre built cause the preson backed out so i kinda got a better deal cause he wanted it gone.
But in 1886 camp i adjusted the PTO lever today. Adjusted pedal location and tightened the pedal up as it had become very sloppy. I also re-ran head light wiring but both my head lights are out so that's another day.
  • chieffan said thank you
#24 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted September 24, 2014 - 10:50 AM
I'll have to call him....   I'm going to ask if he can make some parts to finish my 3 pt.  the bent parts to attatch to my lower arms and the rods...   That metal plate is hard to bend... John..???  doe's he have the measurements for the 3 pt. for a bolens.??
Edited by sodisr, September 24, 2014 - 10:53 AM.
#25 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 24, 2014 - 11:25 AM
Yes he has these measurements. He told me he has thought about making diy kits for those that can weld he may be able to get you those brakets. I would get his lift arms as well have they adjust to level the hitch.
#26 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 25, 2014 - 07:11 PM
So did a little more work today. Changed the oil and filter swapped over to 5w-30 for winter. I also replaced the worn tire rod ends heim joint tie rods and i like them better. So on my quest to whip this 1886 into shape im trying to eliminate the steering slop i replaced the worn joints and tomorrow my new bearing for the top of the steering shaft should be here. This leaves me with the slop in the front axle support. I am planning on buying a pivot pin kit from sam's but it has play front to back is there anyway to eliminate this or should new bushings do this.
  • NJKen said thank you
#27 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 27, 2014 - 05:28 PM
More updates and photos.
Yesterday i drove out to Scranton PA and picked up this snow caster since it's in alot better shape then mine. I also scored a nice set of 26x12-12 and took them to work and filled them 3/4 of the way with washer fluid as it's free at work. With wheel weights about 50 lbs in fluid and 2 link chains i should have no issues this winter getting around with the blower or blade.
DSC_0285.JPG DSC_0286.JPG DSC_0287.JPG DSC_0288.JPG DSC_0289.JPG DSC_0290.JPG
  • NJKen, Rock farmer and chieffan have said thanks
#28 Rock farmer OFFLINE
Rock farmer
  • 1536 Thanks
  • 1432 posts
Posted September 27, 2014 - 06:58 PM
So, that's a single stage snow caster right?
If you don't mind my asking, what did it cost You?
The only large frame blower I've seen around here was $700!
Not in my league!
I have no idea what these large frame blowers are worth.
That's why I ask.
Thanks
Joe
#29 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted September 27, 2014 - 07:14 PM
Not in my league!
That's why I ask.
Thanks
Joe
No problem i have 2 of these and for both i gave 100 each time.
  • Rock farmer said thank you
#30 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted September 28, 2014 - 06:29 PM
The large frame single stage typically go for between $150-350 around here depending on condition. I sold one that I completely refurbished, painted etc for $350. I sold another one that was in good working condition for $175. They show up from time to time. If anyone local to NH or Maine has a junker with a good auger I am looking for an auger that is not all worn thin on the edges please let me know.
