Air Compressor Tank Leaking, Repair Or Replace ?
30 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 28, 2014 - 04:49 AM
Yeah, after changing the drive belt and test running it, when i opened the petcock to drain the tanks i felt it on my hand.
Popped a pin hole this past fall, sanded the spot good and patched it with JB Weld but is leaking again around the patch, looks like the inside of the tank has rusted thin in that spot, would it be worth welding on a patch ? might be too thin, thinking of lining the insides with the Red Kote fuel tank liner.
Or should i just replace the tanks outright ?
Looked at CL and Emglo go for $ 200 and up.
My Emglo twin tank wheelbarrow compressor, picture below :
Edited by trowel, June 28, 2014 - 04:50 AM.
  • hamman and boyscout862 have said thanks
#2 KennyP ONLINE
  • 40,975 Thanks
  • 47,146 posts
Posted June 28, 2014 - 05:08 AM
Time for a tank replacement! That is a bomb waiting to go off!
  • wilberj, hamman, trowel and 5 others have said thanks
#3 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted June 28, 2014 - 05:59 AM
      Unless you are very skilled at welding and know how to correctly repair it I would say replace.  You will be better of in the long run,  good luck
        Pete
  • hamman, trowel, Cvans and 2 others have said thanks
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 28, 2014 - 06:14 AM
It's safer to replace it. You never know how many weak spots are in there. It could blow suddenly, but it's probably more likely to spring a leak and let you down when you need it most.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 28, 2014 - 06:19 AM
Yeah,....figured as much, crap,.......thanks guys, i won't use it anymore, better safe then sorry.
  • hamman, Cvans, HDWildBill and 1 other said thanks
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,142 Thanks
  • 10,206 posts
Posted June 28, 2014 - 07:19 AM
How would a propane tank work? You can get one pretty cheap from a propane dealer. They get the ones in that don't meet current codes.
  • trowel said thank you
#7 NJKen OFFLINE
NJKen
  • 1,362 Thanks
  • 1,284 posts
Posted June 28, 2014 - 08:19 AM
If it were me, I'd replace it. One hole now, but how many more are waiting to finish rusting through and start another leak ?
  • hamman and trowel have said thanks
#8 HDWildBill OFFLINE
  • 8,984 Thanks
Posted June 28, 2014 - 09:22 AM
Good advice.  I had one a couple of years ago that started leaking.  My Son-in-law welded it, but I never trusted it after that so I replaced it.
  • trowel and Cvans have said thanks
#9 MH81 OFFLINE
  • 29,979 Thanks
Posted June 28, 2014 - 10:43 AM
Holes are the warning sign. The news reporters are just waiting for the 911 call now.
Please be careful and replace it.
#10 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted June 28, 2014 - 02:08 PM
Tanks usually cost as much as a new compressor might depending where you buy it. I once took mine to a welder, and he said NO, cause the metals on whole tank bottom could be thin, and hard to weld or just break somewhere else.
  • trowel, Cvans and HDWildBill have said thanks
#11 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted June 28, 2014 - 08:27 PM
Same here replace it. Sell the parts & destroy the tanks so no one else gets hurt.
#12 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 29, 2014 - 05:59 PM
Did some hunting around and my model compressor tank is obsoleted in several places already and the places that has it cost $$$, now that DeWalt owns the Jenny/Emglo line it seems they are dropping a lot of parts.
Shame, the compressor is around 12 years old, ...drop in a bucket.
Would be neat if i could find two 4 gallon air receiver saddle tanks in good shape from semi trailers for cheap, cut the mounting frame, wheel and handles and mount all that onto the new tanks, then clean and line the insides.
Then again it would be cheaper just to buy another used one.
Edited by trowel, June 29, 2014 - 06:00 PM.
#13 MH81 OFFLINE
  • 29,979 Thanks
Posted June 29, 2014 - 06:01 PM
Sorry to hear that you can't get parts. That sucks.
#14 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted June 29, 2014 - 06:10 PM
Not all bad though, i can still rebuild the compressor pump right now, i may do that.
#15 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted June 29, 2014 - 07:12 PM
I know what it's like giving up a compressor just because the tanks are bad especially a gas engine type & being an Emglo. I had one years ago & was going to do this but sold it for parts. Look into getting two of these & ganging them together.
http://www.tractorsu...nk?cm_vc=-10005
  • trowel and HDWildBill have said thanks
