Repower A John Deere 314
14 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted June 26, 2014 - 10:21 PM
Any ideas on what would be good to repower a John Deere 314? Motorcycle engine?
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted June 26, 2014 - 10:41 PM
briggs v twin there hydrostatic so whatever  how about a 351 Cleveland? might take some work but you could make it fit
#3 Bill 76 ONLINE
Bill 76
  • 2,011 Thanks
  • 1,207 posts
Posted June 26, 2014 - 10:52 PM
Briggs sounds good to me---------------on the other hand if your going Ford power find the rare BOSS 302    tons of power at WOT :D
  • superspeedex said thank you
#4 Cvans ONLINE
  • 7,282 Thanks
  • 6,376 posts
Posted June 26, 2014 - 11:04 PM
Diesel Diesel Diesel, and just in case you missed it you might consider a Diesel.  :thumbs:
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 27, 2014 - 06:32 AM
The problem with repowering a 314 is that for most engines you need to change from the stock drive shaft to one with U joints or modify the frame to lower the engine. Most engines have a higher crankshaft height than the K 321 which means they won't line up to the transmission without a u jointed drive shaft.
#6 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted June 27, 2014 - 08:22 AM
I saw a person that put a flathead ford in a John Deere 200
  • superspeedex and Bill 76 have said thanks
#7 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted June 27, 2014 - 09:16 AM
I have no experience with them but this is available.  I have considered it for my 312 because I think it would look cool hanging out the side of the hood supports. and would make it a snow moving monster with the 49 blower.  I would probably paint the red parts on the engine black or green...
http://www.smallengi...ategory=1710197
Jim suggests the 18 also:
http://www.jimsrepai...com/Engines.htm
Edited by Trav1s, June 27, 2014 - 09:21 AM.
#8 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted June 27, 2014 - 09:28 AM
Here is a thread on another option:
http://www.weekendfr...335&page=168991
I am not sure but think that 14HP Vanguard might have a bit smaller dimensions making the swap easier.
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted June 27, 2014 - 09:46 AM
the 14 and 16 hp vasnguard are identical except the carbs same with the 18 and 21 has well the 21hp has a 2 barrel carb and the 23 has a high lift cam with you guessed it a slightly bigger carb as far as i know the block on all them except for minute differences.
Awhil eback we repowered a 317 with a 20 hp honda engine with one of those repower kits and everything bolted right up except we had to put a 1 inch body lift on it because the valve cover hit the side shield but that tractor ran great and was powerful
  • Trav1s said thank you
#10 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 27, 2014 - 02:51 PM
From my experiences I was able to replace the K series Kohler with another CH series Kohler with only minor differences. The shaft adapter for the flywheel even bolted on . and they have a small package for such big power. So I would try a Kohler V-twin .
#11 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted June 29, 2014 - 01:45 PM
CH series is the replacement for the K series with a solid state ignition?
#12 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 29, 2014 - 08:21 PM
I don't think so? As the ignition and mounting bolt pattern are different. But it fits quite well and most of the tough stuff works right out.
#13 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 01, 2014 - 05:50 AM
I think the Magnum was the direct descendant of the K wasn't it. Pretty much a bolt in. Trying to find a good used low hours replacement for a K series isn't easy around here.
#14 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 01, 2014 - 09:24 AM
Believe it or not when i repowered my speedex the 16 hp v twin was a complete bolt in of the 8 hp briggs i just had to relocate the gas tank and make a different airfilter and make and oil filter block off
#15 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted July 01, 2014 - 01:22 PM
I repowered a JD140H3 for less $200 including a $140 muffler (that I ended up replacing later because it was so close to the PTO clutch the belts kept melting); plus $400 for the used used 16 hp B&S Vanguard horizontal twin.  Even kept the declutcher.
Probably have sixty hours on it now with now problems at all, well except two $40 belts..
