Oil
7 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted June 26, 2014 - 05:54 PM
What oil do you use in old 60's/70's gts?
Just wondering because all of mine are in need of oil and I would rather buy a case of one brand and weight.
#2 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted June 26, 2014 - 05:56 PM
SAE 30 Weight
#3 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 26, 2014 - 07:09 PM
Rotella sells 30W in gallon jugs!
#4 2broke2ride ONLINE
2broke2ride
  • 40 Thanks
  • 38 posts
Posted June 26, 2014 - 07:20 PM
30wt non detergent for anything that doesn't have a filter. I was told by an old timer that non detergent oil lets microscopic metal particles fall out of suspension and settle to the bottom of the sump instead of circulating through the motor which is what you want if you have no filter. If you have a filter you want a detergent oil as it will hold the particles in suspension where they can be trapped by the filter.
  • sodisr, superaben, LYON222 and 1 other said thanks
#5 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted June 26, 2014 - 07:23 PM
Don't think the brand makes much difference, only personal preference. 30w is the normal, but some engines can use 10w-30. With 10w-30 you have to check the oil more often. Noel
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 26, 2014 - 08:33 PM
I run rotella 15-30 in my car pickup, tractor and both garden tractors.
I see no reason to keep more than one oil in the garage.
The only thing running special oil is the Stihl weed eater because they double the waranty from 2 yrs to 4 if you use their oil.
Edited by JD DANNELS, June 26, 2014 - 08:36 PM.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 27, 2014 - 06:39 AM
30 wt which is harder to find these days. If you want a modern substitute Amsoil makes a synthetic 30w oil.
#8 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 27, 2014 - 01:08 PM
For about 12 years on a few different golf courses I ran 15W40 AMSoil in everything but 2 cycles.  If it had an oil filter I doubled the oil change due hours but if no filter changed as recommended by the OEM.
