Stop Button And Spring
15 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted June 25, 2014 - 06:21 PM
My Waterloo walk behinds all have (or should have) a stop button & spring.  Anybody out there know where to buy them?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2014 - 07:23 PM
I don't have them that big, but I have the ones for Wico magnetos.  It is about an inch long with a red plastic button on the end.
Ben W.
#3 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted June 25, 2014 - 07:56 PM
Ben W.
. Ben can u post a picture of the stop button you have curious if it's the same as what Bolens used? Thanks!
  • superaben said thank you
#4 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted June 25, 2014 - 08:45 PM
I hadn't thought of the Wilco button.  I will check tomorrow to see if it is similar enough.  Looks longer, but I have files.
Edited by New.Canadian.DB.Owner, June 25, 2014 - 08:46 PM.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2014 - 08:48 PM
If the ones on my Handi-Ho's are original, this is the exact match.
Ben W.
  • gunstuff1000 said thank you
#6 wilberj ONLINE
wilberj
  • 5,098 Thanks
  • 5,626 posts
Posted June 25, 2014 - 08:52 PM
Ben W.
How much do you get out of them?  Bolens used them on most of there stuff in the 50s.
#7 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted June 25, 2014 - 08:56 PM
Ben W.
. Yea let me know how much you need a piece for those I could use a handful?
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2014 - 09:05 PM
The stop switches are $2.25 each.
I'm not surprised.  So did everyone else.  Wico still makes them, that's the only reason I can get them without reproducing them myself.
Ben W.
#9 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted June 25, 2014 - 09:09 PM
Ben W.
. Ok I will take a dozen how do u take payment?
#10 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2014 - 09:13 PM
PayPal works fine for me.  I sent my email address along in a PM.
Ben W.
#11 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted June 25, 2014 - 09:48 PM
Ben W.
. Thanks Ben!!!
#12 MH81 OFFLINE
  • 29,979 Thanks
Posted June 25, 2014 - 09:57 PM
If the wico doesn't work, I can't think you couldn't make your own somehow. The steel in an old set of feeler gauges might be a good option for the spring steel?
#13 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2014 - 10:18 PM
That's true, too, Alan.  I've used pieces of old recoil starter spring for similar applications.
Ben W.
#14 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted June 26, 2014 - 06:23 PM
Ben W.
The Wilco button is smaller.  Mine is .640" diameter & .475" tall, whereas the Wilco button is .425" & .400" (all numbers approximate).  That said, I did find one of my missing stop buttons.  It had been used to replace a Wilco button.  Can you add 4 buttons to my order?
Still looking for a replacement, if anyone out there knows where to get the larger stop button & spring.
Edited by New.Canadian.DB.Owner, June 26, 2014 - 06:23 PM.
#15 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 26, 2014 - 07:22 PM
4 buttons are on it now, Mark.
Ben W.
