Kohler K 90 Engine
kohler k 90
12 replies to this topic
#1 jgtools OFFLINE
jgtools
  • 5 Thanks
  • 22 posts
Posted June 24, 2014 - 06:11 PM
Does anyone have a k90 for sale in running/working order. Would be used on my bolens super versamatic, thanks let me know .jim
#2 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted June 24, 2014 - 07:13 PM
What's all wrong with the one on the tractor?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 24, 2014 - 08:38 PM
That can be a hard thing to lay grubby hands on.  What kind of crankshaft do you need?  Straight keyed?  Gear reduction?
Ben W.
#4 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted June 24, 2014 - 08:50 PM
Ben W.
Straight and keyed. Versa-matics didn't have a gear reduction.
#5 jgtools OFFLINE
jgtools
  • 5 Thanks
  • 22 posts
Posted June 24, 2014 - 09:01 PM
I brought the k 90 to a small engine guy, he said it would be cheaper to find another one in running condition. Not sure what is all wrong.
  • superaben said thank you
#6 jgtools OFFLINE
jgtools
  • 5 Thanks
  • 22 posts
Posted June 24, 2014 - 09:02 PM
Straight keyed,no reduction gearing
#7 MH81 OFFLINE
Posted June 24, 2014 - 09:40 PM
I would ask for a little more information on the failure(s) or problems with the engine.
The K90 I was exposed to had an experimental Bosch ignition system. I think they are NLA and possibly expensive when you do find one. The K91 is a similar engine with more standardized parts. If you have to look for one, you might consider it as an option. I was told the tins would exchange too, but I dont know for sure.
  • jgtools said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 24, 2014 - 09:44 PM
I'd be asking questions if I was you.  Some of these small engine guys see an oldie like a K90 and they want to run and hide.
I sell rebuild kits for them, and it is absolutely something you could do yourself, too.  Ignition parts can be a bear, but you can convert it to a later style ignition unit, too.  It should have a Phelon or Scintilla/Bosch magneto from my understanding.  You can still get parts for both units.
Ben W.
  • MH81, GTTinkerer and jgtools have said thanks
#9 jgtools OFFLINE
jgtools
  • 5 Thanks
  • 22 posts
Posted July 02, 2014 - 09:57 PM
hi all, have not had a lot of time to work on this lately, i did pick the engine up from small engine mechanic, it was obvious,he wanted nothing to do with this old engine. with that said, I went to work , and removed  the flywheel, the flywheel did come off, but it cracked during removal, also i found that one of the magnets was broke, and that was the noise i was hearing when i would crank the engine over.   so , who can sell me  the following :   condensor  , points,  flywheel w/magnets.   let me know. thanks Jim.
dont laugh to hard, but I had no way to test coil, so i decided to have wife pull the engine over , while I hand held the plug wire, yup, it bites hard.     not sure why points or plug have absolutely no spark, when juice is obvious flowing thru plug wire.??
#10 jgtools OFFLINE
jgtools
  • 5 Thanks
  • 22 posts
Posted July 02, 2014 - 10:03 PM
after i cleaned things up bertter, the magnets look good, the broken piece looks to be a piece of casting,?  not sure  its not a magnet at all, not sure how the piece got there
#11 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted July 03, 2014 - 04:56 AM
It may be the spark plug is grounding out internally, try another.
#12 Bolens 1000 OFFLINE
  • 15,288 Thanks
  • 18,233 posts
Posted July 03, 2014 - 11:24 AM
I can sell you an ignition tester that can tell you whether or not you have spark or weak spark . May be better than shocking yourself :D
They start around $13 then go up depending how fancy of one you want.
  • GTTinkerer, Lauber1, trowel and 1 other said thanks
#13 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 03, 2014 - 08:01 PM
I have the condenser and points in stock.
Ben W.
