Case 155 Mower Deck Help
5 replies to this topic
#1 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted June 24, 2014 - 12:42 PM
Got a case 155 and was looking for pictures of the E44 deck.
Because I don't think deck I have is for 155,I think somebody
As rig it up on it. The deck sits about 2" lower on left side then right side.I have it setup right now with left lift arm in top hole.right side in center hole. And 3" of clearance from driveway to blade edge both sides. But the arm lift adjusting nut is screw all the way in and when I lower lift arm I'm cutting 1" off ground.
Edited by anixon92, June 24, 2014 - 12:51 PM.
#2 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted June 25, 2014 - 05:24 PM
Ok it is a 44" deck just don't know if it a E44 or E44T
here are some pictures of deck.
i would like is the length of the lift rod on left side
bottom lift links on left side.
because parts book shows different parts numbers for E44 and E44t
#3 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted June 25, 2014 - 07:56 PM
You might be better off going to one of the CCI forums for this tractor. The more limited the run more the become collector item then worker. And the Colt collectors are well versed in all aspects of these machines. I'm not saying no one here would help you cause all on here are a great and if any one here has that information you would surely receive it. I do not believe to many on here have that tractor. The hard core case case collectors are usually color blind meaning they don't cross over to other forums some do but theres a lot that wont. I belong to a couple of them I know some that come here once and awhile but they might miss your post. And like here most would give you the shirt off there back if you needed it. Hope you find the help you need. Thats why I like this forum if can't figure it out they will point you in the right direction.
#4 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 286 posts
Posted June 26, 2014 - 09:47 AM
Your deck looks just like mine if I can remember I will see how long my lift rods are
#5 Rick OFFLINE
Rick
  • 15 Thanks
  • 168 posts
Posted June 26, 2014 - 12:15 PM
That looks like the deck on my 190. I can't tell you about the lift rods. I know this don't help much but you will find someone that can help with this. Good luck
#6 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted June 26, 2014 - 03:43 PM
I talk to a case dealer today and they have 3 155 in shop right now with 3 different length lift rod length.
Confusing. Need a shot
